Rear wheel stud replacement
Old Mar 25, 2008 | 09:57 PM
Dante7's Avatar
Dante7
Default Rear wheel stud replacement
How do you replace a rear wheel stud on a 75 vette? I have the wheel and rotor off but the whole parking brake setup has me confussed.
Old Mar 25, 2008 | 10:13 PM
A88FXRS's Avatar
A88FXRS
cut the stud off flush and drive it out.
Old Mar 25, 2008 | 10:15 PM
Dante7's Avatar
Dante7
well how do you get the new one in??
Old Mar 26, 2008 | 01:58 AM
A88FXRS's Avatar
A88FXRS
push new stud thru from back and pull thru with lug nut and washers until splines are seated.
Old Mar 26, 2008 | 06:22 AM
Dante7's Avatar
Dante7
Well either i am missing something obvious or something because there is no way to get the stud in from behind its to long to fit between the space where the parking brake shoes are to get it into the hole.. can anyone explain how to acheive this
Old Mar 26, 2008 | 11:10 AM
wfo76's Avatar
wfo76
Yeah, I was told it could be done but couldn't find a way to do it either.
Looks like drilling an access hole in the rear of the backing plate to pass the stud through will be the easiest way short of pulling the spindle.
Old Mar 26, 2008 | 04:31 PM
saudivette's Avatar
saudivette
You'll need to remove the caliper, the rotor and the park brake setup then drill a hole in the backing plate so that you can rotate the axle and line up the hole you drilled with the hole in the flange then slide the new stud in.
I wouldn't beat the broken stud out or your risk damaging your bearings. I used a cheap 'C' clamp like a mini press and pushed the broken one out then used another 'C' clamp (buggered the first one) to pull the new one up until it was seated. You could also pull the new one up with an old nut.
Do a search or read gtr1999's papers
Old Mar 26, 2008 | 04:55 PM
Silver00V6Camaro's Avatar
Silver00V6Camaro
I have a 75 and replaced all wheel studs its very easy. The fronts have a large enough hole in the dust sheild to remove the stud. The rears i took a dremel and cut one big enough. All you do is just hammer out the old studs then in stall the new ones. use some washers and a old lug nut to press the new ones in. I did not remove the rotors on mine. if you have to get a punch to get the old one out. It only took a few hours to do this too
Old Mar 26, 2008 | 10:08 PM
wombvette's Avatar
wombvette
Or simply get a lug that is 1/4 inch shorter. Unless you are running some kind of special wheel that needs the longer lugs.
Old Aug 5, 2012 | 02:22 PM
Hans4real's Avatar
Hans4real
Default Quality Studs
Anyone know of stronger longer replacement studs they can recommend for the rear replacement on a '71?
To Rear wheel stud replacement
