Changing over to a mini starter help!
Old Mar 26, 2008 | 09:00 PM
Theiskell's Avatar
Theiskell
Default Changing over to a mini starter help!
I am changing over to a two post mini starter. My question is can I just pick up my switched hot to the coil from the yellow wire on the wiper motor. I think it’s the yellow wire…I have the engine out right now so I am not sure on that one, if I am wrong please correct me. This is on a ’69 any help here would be great.
Old Mar 26, 2008 | 10:03 PM
wombvette's Avatar
wombvette
Why would you want to change if from the one that it is on now?
Old Mar 26, 2008 | 10:24 PM
Theiskell's Avatar
Theiskell
The original starter had a third post that fed voltage up to the positive on the coil. The new mini starter I have only has two posts. I will have the purple wire that engages the bendix (sp) on one and the battery cable on the other. What I have been told is that I need to get power for the coil from somewhere else. The wiring diagrams I have are not much help on this.
Old Mar 26, 2008 | 11:16 PM
wombvette's Avatar
wombvette
Use the original wire that went to the coil through the resistor to operate the coil. Correct, there is no Ignition terminal on that new starter. I think that there is a post on the end of the solinoid that feeds the field windings. Find that terminal and use the old wire from the starter on that one back to the hot side of the coil. Wont be as good as the original, but should work.
Old Mar 26, 2008 | 11:18 PM
Theiskell's Avatar
Theiskell
Ok, I got this from a web site (I think summit) does this sound correct. A 10A/250 volt diode.. that sounds huge to me
R-TERMINAL
On older vehicles, mostly with breaker points, there was an extra terminal and wire on the original
starter (the MSD Starter does not have this terminal). This extra terminal served as a ballast resistor
bypass. When the starter was cranking, 12 volts would be supplied on this terminal and directly to the
coil positive terminal for starting assistance.
Most ignition systems today do not need this terminal, however, if your ignition has no voltage when
cranking you can wire a system. Connect a 10A/250V diode in-line with the motor side of the solenoid.
The banded end of the diode goes away from the starter. This allows current to go to the ignition coil
during cranking and will not feed back to the starter while the engine is running.
Old Mar 26, 2008 | 11:22 PM
71406's Avatar
71406
Its been a while so I may be wrong on this...hopefully someone will correct me if I am. There are two power lines going to the coil. One comes from the junction box on the firewall and has a resistor that reduces the 12 volt current. The other power lines comes from the starter (the one you are referring to) and this line doesnt have a resistor and therefor is full battery voltage. To help start your car you need full voltage going to the coil and when you crank your starter it supplies the full voltage. However, once your car is started the power supply coming from the firewall with the resistor feed the power to the coil. You do not want to run full power to you coil if you have a stock point/condenser ignition system.
When I upgraded my ignition I removed the point set-up and now run a system that allows me to run full power to the coil. Therefore I eliminated the line from the starter and replaced the wire from the junction block with a new line that didnt have the resistor.
I did this a few years ago so I have I got this correct...and I hope it helps.
Old Mar 26, 2008 | 11:33 PM
Theiskell's Avatar
Theiskell
Thanks Paul,
That was a very good description and makes things a bit more clear. I am thinking I am going to change my distributor over to electronic so that may be the way I go.
Old Mar 27, 2008 | 12:40 AM
Solid LT1's Avatar
Solid LT1
Wire from "R" terminal on starter soleniod is to bypass resistor wire in harness while starter motor is cranking and battery voltage is lower. You can insulate and zip tie wire back to harness and ignition coil will be fed 9.8VDC or so from resistor wire intregal to wiring harness or go to fuse block and look for 12VDC auxillary ignition terminal to take a full 12VDC to coil IF your ignition set-up allows full coil voltage (Pertronix Ignitor or similar set-up.) You SHOULD NOT do this if you are running ignition points as the contact set will burn from excessive current across the points.
Old Mar 27, 2008 | 09:20 AM
wiseman79's Avatar
wiseman79
Thanks Paul,
That's what I did when I swapped to a mini starter. I was told when I posed this same question that you could just eliminate the wire from the starter to the ignition even with a points system, and as long as your battery wasn't weak it would still start fine. I never tried this however, and personally I'd rather have the extra juice for that day I leave my lights on.
Old Mar 27, 2008 | 10:53 AM
pws69's Avatar
pws69
When the starter is engaged, the "R" terminal is electrically the SAME point as the bottom LARGE lug that goes to the actual starter motor. You can replace the lug on the wire with a large one and attach it to the bottom large stud to deliver the full 12V when starting.
Old Mar 27, 2008 | 11:38 AM
Theiskell's Avatar
Theiskell
If I do that would the power coming from the firewall not feed back to the starter and keep the starter engaged? There is a second wire that has a resistor that supplies 9.8 constant volts to the coil.
Old Mar 27, 2008 | 11:44 AM
jackson's Avatar
jackson
If you use a late starter with points ignition ... and require the extra booster terminal on solenoid cap like your old starter has ... simply take your new starter to a reputable local starter & alternator rebuilding shop ... have them install a solenoid cap that has the extra boost terminal ... it's not brain surgery. And, I'd trust that for long-term reliability a lot more than a diode, wiper wires etc.
Old Mar 27, 2008 | 12:43 PM
pws69's Avatar
pws69
Yep, excellent point. A diode would take care of that. You pointed that out in a previous response where you have a paragraph titled "R-TERMINAL"
I seem to remember that there was some vendor who had a "kit" to do this very thing and it probably included the diode.
Old Mar 27, 2008 | 03:10 PM
markdtn's Avatar
markdtn
You could also use a relay triggered by the purple start wire and powered by battery power.
To Changing over to a mini starter help!
