intake heat solution?
Old Mar 27, 2008 | 05:53 PM
bondoboy's Avatar
bondoboy
Default intake heat solution?
Awhile back, someone mentioned painting the bottom of an intake to stop the heat. I could not find the original post. What kind of paint should I use and what kind of special prep should I do on an aluminum intake? Thank you.
Old Mar 27, 2008 | 06:26 PM
TimAT's Avatar
TimAT
No idea about paint, but there are several different heat shields that go in the valley below the intake. Or get some tin and make one. All it's got to do is snap in under the intake to keep hot oil off. If you're going to do that, make sure to block the heat crossover if your intake has one. No sense in closing the door and leaving the horse outside.
Old Mar 27, 2008 | 06:47 PM
Duke94's Avatar
Duke94
One of the Speed channel car shows last week said to paint the bottom side of the manifold with High Temp White paint and the top side black.
Old Mar 27, 2008 | 08:02 PM
bondoboy's Avatar
bondoboy
I appreciate the help, guys. I have a carb heat shield and I plan to buy the baffle that goes under the intake. My intake has no crossover, so no problem there.
To intake heat solution?
