1971 LT-1 Radiator Question
Old Mar 27, 2008 | 06:08 PM
wallifishrmn's Avatar
wallifishrmn
Default 1971 LT-1 Radiator Question
I had a leak in my 1971 LT-1 radiator and am having recorred. The bottom had an L-shaped stopcock with a hex nut on the end for a drain. The radiator shop wants to know if this is original or whether it had a typical radiator draincock that drained straight down. Can Someone let me know what the original had? Thanks
Old Mar 27, 2008 | 06:27 PM
Barry's70LT1's Avatar
Barry's70LT1
Mine is as you describe, an L-shaped fitting with a hex nut on the end for a drain.
It would seem logical that it would be the same in '71.
Barry
Old Mar 27, 2008 | 08:32 PM
wallifishrmn
Thanks. Heard from another 1971 LT-1 owner-who also has theL-shaped drain. Must be the original!!!!!!!!!!!!
Old Mar 28, 2008 | 10:07 AM
72-LT1's Avatar
72-LT1
Any one have a picture of that. I took mine out last week and I ended up just removing hoses to drain. Mine looks like just a bolt head at the bottom, if I drained it like that it would have went all over the frame.
I was going to get mine tested and cleaned before I put it back in and was thinking of changing the plug so I could drain it easier, so if it is not correct I will get the drain changed.
I havent' looked at the numbers but it has the correct tags so I am pretty sure it is the orig rad. I just got my water pump back from Author Gold and it was the correctly dated pump.
Old Mar 29, 2008 | 10:19 AM
72-LT1's Avatar
72-LT1
No pictures guys?
Old Mar 29, 2008 | 02:42 PM
wallifishrmn
Mine is at the radiator shop being recorred. I will post a picture when I get it back next week.
To 1971 LT-1 Radiator Question
