Clutch Experts?
Old Mar 28, 2008 | 07:58 PM
ARCH's Avatar
ARCH
Default Clutch Experts?
Did a big burn out (at the track) and thick I fried my clutch. I have a new street / strip clutch which we will put in asap, but if someone could help explain what might have happened I would appreciate it. Got the rpms up and dropped clutch with car in second gear, applied brakes and held it for several seconds. Produced some good smoke. I found out afterwards one wheel was'nt turning (that problem has been rectified). After burnout put car in first and it did'nt respond, shifter felt like it was stuck, clutch was gone had to drive down return road at 10 mph.
Now the question I have is the clutch fork is very tight, as I understand it should have some play, any explanation to why the fork is so tight, is this a symptom of a worn clutch or is it possible it is out of wack and there could be something left. The clutch had about 70 runs on it, and had shown no signs of wearing out before this catastrophic falure.
Any comments?
Old Mar 29, 2008 | 12:38 AM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Curious,..why did you select 2nd gear for your burn-out?
Old Mar 29, 2008 | 10:24 AM
brngrhd's Avatar
brngrhd
doing second gear burn outs is normal to get the wheel speed up....
the reason that the fork it tigher is if the disc got worn badly on that run or if the material was knocked off the disc the pressure plate will have to travel in farther to apply what is there thus makeing the fork push farther forward where it is most likly pushing against the linkage that can't travle any more.
Old Mar 29, 2008 | 11:07 AM
stingr69's Avatar
stingr69
I would guess you cooked the pressure plate and /or disk. Too much heat. warped springs, warped diaphram, time to pull the tranny.
Just a guess.
-Mark.
Old Mar 29, 2008 | 08:04 PM
ARCH's Avatar
ARCH
Was testing today, no doubt clutch is slipping pretty bad. Could'nt even get car to stall out with parking brake on up a hill, . Figure I probaly heated it up quite a bit, will find out for sure next week. Thanks for the responses.
To Clutch Experts?
