I think this is bad...
Old Apr 1, 2008 | 04:26 PM
kdf1986's Avatar
kdf1986
I think you have to replace that part, or worse case the entire differential if you cant find the part. Putting that part back in just looks like you are asking for more trouble. The next time that this starts to separate you might end up with pieces of it inside the differential, and then you can imagine the mess that it will make.
Of course this will happen on a Sunday weekend ride out in the country with little to no cell phone coverage. Thats the downside of when it will implode.
kdf
Old Apr 1, 2008 | 04:53 PM
GTR1999's Avatar
GTR1999
If it were mine and I wanted to try and save it( I really would install an iron unit) I would machine a couple of steel caps and look into a steel thread insert for the pads.
Old Apr 2, 2008 | 01:02 AM
danno12345's Avatar
danno12345
Thanks Gary, I think that's what I'll aim for until I can scrape together the cash for a better solution.
Would I be able to use the caps out of a scrapped iron corvette diff? I don't know if the bearing races OD and the cap bolt spacing are the same in the Aluminum & Iron ones.
KDF, I completely agree. I'm not going to put it back in, but I'm kind of impressed that I apparently have been driving around on it without an implosion.
Stinger, based on what I see & hear & can afford right now, I will be pulling it out/apart again, so I'm going to do what I can now to get it driving, then fix it better later when I can (or when it breaks real good...)
By the way, keep up the good posts. I'm not sure which I like more - the work you do or the detailed way you write it up.
Dan
Old Apr 2, 2008 | 02:25 AM
stinger12's Avatar
stinger12
Dan
Thanks. I completely understand the budget thing. Find a fix for now and reinstall it back into the car, and go have some fun
Old Apr 2, 2008 | 12:12 PM
tracdogg2's Avatar
tracdogg2
Dan,
You can't use the caps from an iron diff. There is a lip inside the cap to retain the bearing. The design is the biggest problem with these diffs. If you can get a used cap from an 80-82 I should be able to machine it to fit.
Mike
Old Apr 2, 2008 | 03:20 PM
jdmick's Avatar
jdmick
I don't know what the market is now but I found a nice 3.36 for my 75 on Epay a couple of years ago for around $300. Like KDF says, the idea of something flying apart at the wrong time in the middle of nowhere would bother me.
Old Apr 2, 2008 | 03:25 PM
Meh's Avatar
Meh
A little Zaino would fix that right up.
Old Apr 2, 2008 | 03:49 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Dan
I think it would be cheaper to find a usable iron differential and install it to the batwing than trying to machine steel caps.
Old Apr 2, 2008 | 04:44 PM
stinger12's Avatar
stinger12
what the heck is zaino?
Old Apr 2, 2008 | 10:42 PM
40ZR1's Avatar
40ZR1
Taking a cap from another diff won't work, they're machined as a unit. Another cap might look like it works but nodda! Thats like swapping the caps on your connecting rods.
Old Apr 3, 2008 | 01:40 AM
gleninsandiego's Avatar
gleninsandiego
http://yuma.craigslist.org/pts/628038626.html
Old Apr 3, 2008 | 02:11 AM
Meh's Avatar
Meh
Originally Posted by gwgwgw
Sweet, it even fits an 83...
Old Apr 3, 2008 | 11:49 AM
  #33
tracdogg2's Avatar
tracdogg2
Sure it will. I will have to re-machine the bore and the pads.
Mike
Old Apr 4, 2008 | 01:26 PM
  #34
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
It's a "miracle polish" that a lot of guys swear by. With all the testimonials about it reviving horribly faded paint, it's become a joke that it can fix anything.
Old Apr 7, 2008 | 09:38 AM
  #35
danno12345's Avatar
danno12345
I've got a possible line on an aluminum diff locally. How can I tell, and what will be the consequences if it's a manual tranny car? Mine's auto.
Thanks!
Dan
Old Apr 7, 2008 | 12:16 PM
  #36
theoUK's Avatar
theoUK
Mike
The cap's contact pads aren't even machined in these DANA 44s - I guess another reason why it has a poor reputation for strength/quality. It's just two "as cast" surfaces butting up against one another. That might make it tricky to get another cap to fit.
I guess the best bet might be to take a "new" cap, skim a few thou off the pads - to drop it down and give some meat to machine out - then bolt it up to the casing and then bore the whole lot out? A job for the milling machine!
Old Apr 7, 2008 | 12:20 PM
  #37
stinger12's Avatar
stinger12
Trust me, never doubt tracdogg2. He has been working on vettes for 30 years and knows absolutely everything.
To I think this is bad...
Old Apr 7, 2008 | 08:59 PM
  #38
danno12345's Avatar
danno12345
I went and looked at the local diff, here's what it was:
A complete rear end, from the crossmember before the kickup, to the rear spring.
It includes:
complete trailing arm assemblies, bearing carriers, rotors, calipers, shocks. Halfshafts, strut rods, strut rod bracket, iron differential, differential mount crossmember & leaf spring.
He'd like $400 for it.
The only number I saw on the housing was 3899143. I didn't know where to look for the date. Definitely iron, definitely pre-80.
Whaddya think? I could probably recoup most of my cost by selling the parts I don't need anymore... I'm just not sure what the inside of the diff looks like, or even what gears are in it. Not sure I'm up to the project at this point.
Discuss....
Dan
Old Apr 7, 2008 | 09:32 PM
  #39
tracdogg2's Avatar
tracdogg2
Theo,
That's exactly how I would have to do it.
Mike
Old Apr 7, 2008 | 10:20 PM
  #40
63mako's Avatar
63mako
St. Jude Donor '08-'09
It includes:
Discuss....
Dan
That is a steal. If it was closer I would buy it if you passed.
