Hood clearance with tripower!
Old Mar 30, 2008 | 10:15 PM
howarsc's Avatar
howarsc
Default Hood clearance with tripower!
I put 1/2" ported carb spacers on my 68 tripower and the factory hood closes. K&N filter. I doubted it would work butit did and now it runs leaner (a good thing). And I had to increase the secondary spring pressure. Solid motor mounts are a must.
Old Mar 30, 2008 | 11:37 PM
eastltd's Avatar
eastltd
Do the solid mounts sit the block lower for hood clearance or are you referring to the mega-torque that tri power puts out?
Old Mar 31, 2008 | 10:25 PM
howarsc's Avatar
howarsc
mostly the torque but any room helps. Plan "b" was to offset drill the solid mounts about 1/8-1/4".
To Hood clearance with tripower!
