Hum, Grind, Clunk?
Old Apr 1, 2008 | 07:53 PM
Mia's Avatar
Mia
Default Hum, Grind, Clunk?
Hello, I noticed a kinda of hum, grind/clunk which appears to be located near the tranny and or drive shaft.. It is really hard to say which.
Anyway, I took an extended drive today on the interstate, perhaps 100 miles round trip at speeds around 70-80... The hum, could be my new tires for all I know. However, coming to a stop and decelerating off the off ram then coming back into stop and go traffic it seemed like there was kinda of a jump or jolt and clunk in the drive train. It felt like the drive shaft or tranny was gonna fall off. The drive back was fine.
Now I have noted here before that I have a small transmission fluid leak, but I checked that and keep it topped off. I've not pulled the tranny yet for a rebuild or service, so I am wondering if I have more trouble than I thought?
Any ideas on what to look for? This is a T350 auto on a 79 Vette, stock, original. Stock L48 motor and torque converter. Thanks!
Old Apr 1, 2008 | 08:00 PM
weimer20's Avatar
weimer20
Hmmm.... Does the humm change in pitch as related to the speed you are driving? Happening in all gears? When you top off the fluid in the trans, are you filling it with the engine running?
Old Apr 1, 2008 | 08:04 PM
Mia's Avatar
Mia
I did not really notice until we were consistently cruising at hyway speeds. So I guess the later gear is all I noticed, ie., 3rd.
Yes, filling and checking with engine running and hot. It's only losing it after it is parked. And then it spits out like a table spoon or less each time. So it is not losing a huge amount. Also, the transmission does not feel like it is slipping. It feels quite responsive actually.
Old Apr 1, 2008 | 10:00 PM
ENG40's Avatar
ENG40
Did you check the u joints? It might be chewing up the needle bearings in one of the caps.
Old Apr 1, 2008 | 10:02 PM
Mia's Avatar
Mia
Good idea.. From the sound and localization of the sound, it sure seems like that might be it. Thanks! I'll have to look at that this weekend!
Old Apr 1, 2008 | 10:13 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
Sounds like bearings, but also check your wheel nuts, as you mentioned new tires.
Old Apr 2, 2008 | 06:26 PM
weimer20's Avatar
weimer20
I like the suggestion regarding checking the universals on the driveshaft. Loose lug nuts is also a possibility that has been suggested too. I'd certainly go that route first. I would doubt it's the trans at this point.
Old Apr 2, 2008 | 06:54 PM
Mia's Avatar
Mia
I think I will check wheel bearings and the u-joints first.... Now I have a nice weekend project to work on. Gives me an excuse to repack the bearings while I am at it. Thanks again guys!
BassCat's Avatar
BassCat
I would also check for a cracked yoke on your drive shaft. I had one on mine and it made a similar clunking noise.
Old Apr 2, 2008 | 08:04 PM
moosie982's Avatar
moosie982
Straight ahead or turning ?, may be the posi grabbing & releasing and the hum , could it be rear end gear noise ? Peace,,,Moosie
Old Apr 2, 2008 | 10:40 PM
auctionman256's Avatar
auctionman256
check the haft shaft yokes
To Hum, Grind, Clunk?
