Engine build about to commence...
- Crane Hydraulic roller cam (for reliability reasons, I don't want to mess
with a flat tappet cam and grinding lobes)
- Edelbrock performer heads
- Edelbrock intake manifold
- Scat 383 rotating assembly
- Hypereutectic pistons
- plasma moly rings
- ARP bolts throughout the entire engine
I'm still waiting on hearing back from him on a quote, so I'd like to get more specifics on the parts you guys would recommend. He's going to go off of the info I gave him today regarding which specific cam, bearings and intake manifold he'd recommend, but what would you go with?
Cam: I want this thing to be have a mean idle, and a compromise between killing the engine
and streetability. It must be a Crane cam and a hydraulic roller cam. Which Crane cam would you suggest I go with?Intake Manifold: Which Edelbrock intake manifold would you recommend. I'm not sure on which carb to go with yet, so this may be a tough one for you guys
Heads: Are the edelbrock performer heads a good choice?
Rotating Assembly: Is Scat a good reliable brand?
- plasma moly rings
Here is a link to the RHS after market Vortec heads...good price at $325 each for bare heads, or $581 each for assembled for a roller engine.
http://www.racingheadservice.com/Inf...rtec-Heads.asp
The Edelbrock manifold is easy to find on Ebay, but here is the description and part number from Edelbrock's site.
RPM Air-Gap Vortec Manifold for Small-Block Chevy (Non-EGR) #75164
find a 350 junkyard engine...out of a truck if possible...it has the complete everything you need to do it right.....FACTORY style, not some dippy street failure prone who knows where/what made it lifters ....
after that you can find your heads and rest of it piece by piece...
I agree with MrVette as well. I am building Curtis74's new engine and we started with a '96 Tahoe 350. It's a Vortec roller engine so it's got factory roller and the good Vortec heads...though we went with RHS heads instead.
Now, we're keeping his a 355, but it would be just as easy to drop a stroker kit in it and get a 388. The 355 was just cheaper and we can always go back in to get more HP later.
The best heads are AFR. Get a set of the new Eliminator 195's are cam with ~230 @.050 lift. Add a RPM AirGap manifold and you are looking at an easy 500 hp.
