exhast valve
Old Apr 3, 2008 | 07:42 PM
V-Rod's Avatar
V-Rod
Default exhast valve
How do you know what your exhast valve opening in degrees is? I am trying to caculate header size and this is one of the varables. I have a 350 crate engine. thanks
Old Apr 3, 2008 | 08:16 PM
A88FXRS's Avatar
A88FXRS
valve opening is usually measured in hundreths of an inch. degrees as relative to what ?
Old Apr 3, 2008 | 09:54 PM
V-Rod's Avatar
V-Rod
I don't know. at Wallace Racing there is a calculater that asks for RPM, CID, and EVO ( in degrees) would the EVO be the 1.60 from my head spec.'s?
Old Apr 3, 2008 | 10:01 PM
V-Rod's Avatar
V-Rod
Thanks Paul I think I got it. If I use the 1.60 without the decemal 160 I get 1.84 tube size and 23" primary. that seems right before When I left the decemal in I was getting a tube size of 1.10" and lenght of 50" I knew that wasn't right.
Old Apr 4, 2008 | 08:38 AM
rclinton's Avatar
rclinton
Veteran: Marine Corps
No. EVO is the degree that the Exhaust Valve Opens. The informaytion is found on the cam card.
Old Apr 4, 2008 | 08:43 AM
gkull's Avatar
gkull
You can pull up any old cam on the crane cam site and get the valve event numbers @ .050 lift
Old Apr 4, 2008 | 11:29 AM
V-Rod's Avatar
V-Rod
so if my engine builder told me that my cam was exhasrt duration @ .50 was 244 that is what they want in the calculation? They are very vage about cam spec's I think it may be like a trade secert for these guys because they told me lift was I-510 & E-510 duration @.50 I-244 & E-244. Are not these numbers usually a little different or did they hand grind them to the same?
Old Apr 4, 2008 | 11:45 AM
S489's Avatar
S489
they can be the same
that calculator is looking for the exhaust event, probably at 0.05, but does not specify - would have to get the book or email the webmaster
the thing looks like it won't give you a header size that you can go out and buy anyway. probably need the book and formula to see what the results really mean
Old Apr 4, 2008 | 11:50 AM
V-Rod's Avatar
V-Rod
the 244 number give bad results. can anyone suggest Primary header size and length based on this info 350" Dart heads 64cc, 200, Holly 4150 650. torque curve 2000-5000, 400ft lb. steep power curve from 2000 to 6000 holding thu 7000 then droping off peak 6700 430HP. engine guy says 1 3\4 talk to Mr. Stahl yesterday he said 1 5\8. The problem is I have factoru side pipe covers I want to run my system under.
Old Apr 4, 2008 | 05:36 PM
gkull's Avatar
gkull
You see these numbers on a cam card?
Cam Timing: TAPPET @.050
Lift: Opens Closes Max Lift Duration
Intake 2 BTDC 40 ABDC 109 222 °
Exhaust 56 BBDC (2) BTDC 119 234 °
It is saying that the exhaust valve closes 56 degrees Before Bottom Dead Center.
IMO - 1 5/8th by @ 30 -34 inches and a 2.5 X 16 inch collector is about the best sub 450 hp header. As you go up in tube diameter the flow is slower so they need a shorter 1 3/4 X 28 primary
Camshaft Specification Card BACK TO LIST
Part Number: 113801 Grind Number: H-278-2 (REPLACES HMV-278-2)
Engine Identification:
Start Yr. End Yr. Make Cyl Description
1957 1987 CHEVROLET 8 GOOD IDLE, DAILY PERFORMANCE USAGE, MILD BRACKET RACING, 3000-3400 CRUISE RPM, 9.5 TO 10.75 COMPRESSION RATIO ADVISED. BASIC RPM 2500-5500
Engine Size Configuration
262-400 C.I. V
Valve Setting: Intake .000 Exhaust .000 HOT
Lift: Intake @Cam 3114 @Valve 467 All Lifts are based
on zero lash and theoretical rocker arm ratios.
Exhaust @ Cam 3294 @Valve 494
Rocker Arm Ratio 1.5
Cam Timing: TAPPET @.004
Lift: Opens Closes ADV Duration
Intake 26 BTDC 72 ABDC 278 °
Exhaust 80 BBDC 30 ATDC 290 °
Spring Requirements: Triple Dual Outer Inner
Part Number 99848
Loads Closed 114 LBS @ 1.700 or 1 45/64
Open 324 LBS @ 1.230
Recommended RPM range with matching components
Minimum RPM 2200
Maximum RPM 6200
Valve Float 6800
To exhast valve
