motor start up
Old Apr 3, 2008 | 10:16 PM
auctionman256's Avatar
auctionman256
Default motor start up
i got my LT1 rendy to start and tried to start it . it turns over but has start yet. the motor is out of a 93 vette. can any one help me?
Old Apr 3, 2008 | 10:20 PM
JustinD's Avatar
JustinD
Did you do anything with it before you put it in? Is the EFI on it?
Old Apr 3, 2008 | 10:31 PM
CheezMoe's Avatar
CheezMoe
St. Jude Donor '11-'12-'13,'19-'20
Hmmm lot's of questions here:
Are you getting Fuel...with adequate pressure? Spark? Is the firing order correct? 93 LT1- That engine had an early optispark system I think. Is that what your using for ignition?
Could be one of many causes.
Old Apr 3, 2008 | 11:10 PM
auctionman256
high presser fuel pump , new computer chip , have done any thing to the firing order , sent my wiring harrrness off and got it fixed and in stalled it as the paper work said too , the has not been start since first of jan. , should i try starting flud ?
Old Apr 4, 2008 | 09:27 AM
auctionman256
can aneone help ?
Old Apr 4, 2008 | 12:27 PM
Steve20's Avatar
Steve20
I know the C4 uses a VATS system through the ignition key as an anti theft device. If it goes bad, the car will not start- was VATS eliminated from your new wiring?
Old Apr 4, 2008 | 04:09 PM
auctionman256
yes i had it done with the new chip i put in the computer.
Old Apr 4, 2008 | 05:07 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Are you getting spark at the plugs?
Old Apr 4, 2008 | 06:38 PM
auctionman256
what a good way of checking this?
Old Apr 4, 2008 | 11:30 PM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
Best thing I can tell you as far as long distance Troubleshooting is to get a FSM for the vehicle the engine/harness was removed from. Start by diagnosing Hard/No start condition.
TPI? TBI? SFI?
Batt voltage?
Fuel Pressure? what psi?
power to coil? output from coil?
Output from distributor?
correct firing order?
I could go on .....
Old Apr 5, 2008 | 12:11 AM
auctionman256
Lt1
Old Apr 5, 2008 | 02:21 PM
AzMotorhead
If you dont have access to a FSM run down to the local library & if they have a online database you can go to Mitchell on line and
troubleshoot it.
I recall having to check for voltage and resistances at the Ignition module. The one under the coil.
Might want to try to checking for codes
Old Apr 5, 2008 | 09:13 PM
wnmech's Avatar
wnmech
I know the F bodies have what is called the optispark installed and it is a high failure item. You may want to see if your engine has one installed. To learn more about the optispark shoot over to LS1.com and do a search. My F body [2001formula] doesnt have it but the earlier ones did.
To motor start up
