fuel draining
Old Apr 5, 2008 | 04:18 PM
painterman52's Avatar
painterman52
Default fuel draining
I`m replacing the fuel line from the pump to the carb. How can I keep the ga$ from draining out?
Old Apr 5, 2008 | 04:21 PM
A88FXRS's Avatar
A88FXRS
will not drain from carb, just the small amount in gas line. crack fitting at pump and drain line. relieve pressure first.
Old Apr 5, 2008 | 04:23 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
Last time I did ours. I used a pair of vise grips, and pinched the line off before the pump. You are still going to spill some fuel that in in the line. Make sure you have a pan, and do not use a trouble light near the fuel spill. I use a rechargable LED light when working on fuel areas.
You can also drain the tank, but thats a lot of work, the choice is yours.
Old Apr 5, 2008 | 04:26 PM
Binnie77's Avatar
Binnie77
Anytime I have to remove the pump or work with lines beyond that point, I always pinch the rubber lines off coming into the pump with needle nose vice grips. I then disconnect the line at the pump going to the carb and let the gas drain back into a container before completely removing the line. If your rubber connecting lines are older and brittle, you may not want to pinch them for fear of cracking them.
To fuel draining
