U joint help.
Old Apr 6, 2008 | 04:27 PM
76projectstingray's Avatar
76projectstingray
Default U joint help.
I will be putting in new u joints all around and need to buy a vise to press them in. Does anyone know how wide i need to open the vise to fit the u joint and the sockets to press them in? Most vise's i see only open 4 to 5 " and I'm not sure if thats enough.
Old Apr 6, 2008 | 05:03 PM
72LS1Vette's Avatar
72LS1Vette
I used an 8" heavy-duty C-Clamp clamped into a vise to press out the old and press in the new U-joints. A regular vise will barely fit the u-joint and a socket but I found it hard to align the joint and deal with the half-shaft moving around. Even if you decide to use a C-clamp buy a vise anyway. They come in handy for all sorts of things.
Rick B.
Old Apr 6, 2008 | 06:19 PM
bonehead2's Avatar
bonehead2
A 6 inch vise and short socket will do. You do need a good vise anyway.
Old Apr 6, 2008 | 06:48 PM
Gordonm's Avatar
Gordonm
I have a 12 ton press in my basement. Be careful on the flanges they can bend easily.
Old Apr 6, 2008 | 06:55 PM
GTR1999's Avatar
GTR1999
Once the joints are out and the bores cleaned up you don't need much. I just did a set of shaft last week and got the caps in flush by lightly tapping them and then used a socket to install so any vise would have worked. Now to remove them is another story and you're better off cutting them out with a O-A torch or die grinder. You have to bolt them on a solid plate first.
Old Apr 7, 2008 | 06:08 PM
76projectstingray
Thanks for the replies, I did read one post that showed bolting the flange to a plate, then I saw one from van steel that showed using a hammer to tap the caps in and I looked for the flange bolted to a plate and it did not look like they used one?
Old Apr 7, 2008 | 06:33 PM
427-390's Avatar
427-390
Are you replacing the half shaft or driveline u-joints? I had to bring my half shafts to a driveline shop to R&R with new spicer joints. Those ****'s were in there good and tight. I tried using a C-clamp u-joint removal tool and they wouldn't budge. Be advised, sometimes the u-joints on half shafts don't want to play nice. Good luck.
Old Apr 7, 2008 | 06:42 PM
jdmick's Avatar
jdmick
I'll agree that getting them out is a much bigger problem than getting new ones in. A torch or grinder work well but you have to be careful what you cut and not bend anything. Nothing complicated but if you have a reasonable shop in the area I'd recommend you take them there, especially if you don't have the proper tools.
Old Apr 7, 2008 | 07:32 PM
GTR1999's Avatar
GTR1999
Use the plate.
Old Apr 7, 2008 | 07:55 PM
L82shark's Avatar
L82shark
St. Jude Donor '08
make the plate, the half shaft u joint flanges cost about 70 bucks apiece. THEY WILL BEND. I used a piece of 3/8ths steel plate and made a template of the flange and drilled the holes and bolted it to it. worked like a charm the 3rd go around!
Old Apr 7, 2008 | 08:13 PM
stinger12's Avatar
stinger12
I bent one of my flanges even with the backing plate. I was able to salvage it and straighten it out.
http://forums.corvetteforum.com/show...849398&page=23
Old Apr 8, 2008 | 07:00 PM
76projectstingray
I'll get a peice of steel and make a mount before i try to get them out. I'm doing the half shaft and drive shaft.
thanks for the replies.
Old Apr 8, 2008 | 08:16 PM
SportsCarsUnlimited's Avatar
SportsCarsUnlimited
Just remove your spindle nut with a 1 1/6 socket, Pull the mounting flange off the spindle and bolt it on the haft shaft. No special tool needed. Easy
David
To U joint help.
