What the hell happened!?
Old Apr 6, 2008 | 05:09 PM
sperkins's Avatar
sperkins
Default What the hell happened!?
1968 vert:
All at once I have:
No brake lights.
No headlights.
No dash lights.
All was working fine the other day when I noticed all the headlights (except 1 drivers side) weren't coming on. I wiggled the wires at each headlight to make sure they were plugged in. After that I have NOTHING.
ALL fuses check fine.
WTF!!!
Old Apr 6, 2008 | 05:53 PM
DZRick's Avatar
DZRick
Have you checked everything in the motor compartment for voltage?
I'd think you either have a big ground problem or the problem lies in the bulkhead connector that connects the fusebox to the forward wiring harness.
Old Apr 6, 2008 | 06:16 PM
sperkins's Avatar
sperkins
That's what I'm leaning towards. I checked for continuity at the fuse block and all is good.
Starting on one thing first, I checked the brake light switch using the (-) battery terminal as ground. It's getting power from the fuse block, but both wires on the switch are hot all the time. I should only be getting power on one side of the switch until the pedal is pressed. This should mean that the lights would stay on all the time - right? But I still have no brake lights - and yes the bulbs are good.
How can I check the bulkhead connector?
Old Apr 6, 2008 | 07:08 PM
DZRick's Avatar
DZRick
The bulkhead connector is next to impossible to get to. I'd just start checking everything in the motor compartment for voltage.
In my car we had one wire pulled out of the bulkhead (couldn't see it) but it was out just enough to prevent my signal lights from working.
As far as your brakes go with power on both sides, yes they should be lite. Is your switch the plunger type 69 up I believe, either way something isn't right there.
Old Apr 6, 2008 | 07:46 PM
sperkins's Avatar
sperkins
Switch is not a plunger style. I guess it's a one-year only deal.
I drove the car last weekend for a few hours with someone following me and they said the brake lights worked fine. They went out when the headlight problem came up (my turn signals do still work however). That is what leads me to believe there is a big problem somewhere.
Old Apr 6, 2008 | 08:44 PM
DZRick's Avatar
DZRick
The brake light switch could be out of adjustment but your brakes would constantly be lite if that were the case.
Here's a pic. of the 68 only brake switch.
Old Apr 6, 2008 | 11:37 PM
DZRick's Avatar
DZRick
Has anyone else got any ideas, granted he's got another Vette but you know he wants to drive the 68.
Old Apr 6, 2008 | 11:42 PM
BigBlockTank's Avatar
BigBlockTank
Check grounds, continuity. I have a power probe that makes it really easy. You can touch a wire and tell if it's hot or ground. You can also apply power or ground. It makes short work of a real problem. Get one off the tool trucks, Matco, Snap-on, etc.
Old Apr 7, 2008 | 12:38 AM
sperkins's Avatar
sperkins
Thanks guys. The swith pictured above is the one I have. I just can't figure out why everything went out.
Old Apr 7, 2008 | 01:10 AM
sperkins's Avatar
sperkins
Wouldn't a bad headlight switch cause all the following issues?:
No headlights
No tail lights
No dash lights
How do I check that sucker?
Old Apr 7, 2008 | 01:30 AM
DZRick's Avatar
DZRick
Scott, check your PMs and read the last paragraph closely. Sorry for being so long winded. Keepin mind that you now have 12 volts on both sides of your brake switch now too.
Old Apr 10, 2008 | 12:04 AM
sperkins's Avatar
sperkins
Anybody got a match?
Old Apr 10, 2008 | 01:15 AM
theandies's Avatar
theandies
Don't torch it, I'll take it off your hands.
Sounds like the connector came off your headlamp switch to me.
To What the hell happened!?
