Need 350 Cylinder Head Information
Old Apr 6, 2008 | 05:21 PM
inex1's Avatar
inex1
Default Need 350 Cylinder Head Information
I have a pair of 350 cylinder heads that I can not identify based on the casting number. They are dual bump heads and the casting number is 8873370 the date code is 1179. So I know they are 1979 heads but just can'f match the casting number, and yes the number is legible and the same on both heads. Does anyone have a more detailed code book ? The heads look to be in real nice shape and I would like to use them as is on my 350 powered 84 pickup but want to know as much about them if possible. Thank in advance for any help you can provide.
Old Apr 6, 2008 | 05:32 PM
sperkins's Avatar
sperkins
Are you sure the number isn't 3873370?
Old Apr 6, 2008 | 05:38 PM
inex1's Avatar
inex1
The 1st number looks like a 8, but even when I tried the 3 I still could not ID the head ?
Old Apr 6, 2008 | 06:49 PM
sperkins's Avatar
sperkins
Sorry - I meant to say 3973370 .
I found this for the 3873370, but the guy read the numbers wrong.
http://www.nastyz28.com/forum/showthread.php?t=99053
If it is 3973370:
3973370....69-70...350..........over the counter in US, Canadian 350/300hp production use in Pontiac, 64cc, straight or angle plug
Old Apr 7, 2008 | 10:13 AM
inex1's Avatar
inex1
If it is 3973370:
I just triple checked the casting number stamp and yes the 1st number is a "3" and the other numbers are very clear so the correct casting number is 3873370. And I just talked to the guy who had the heads and he said that he personally took them off a 1980 Corvette that had a 350, but he was not sure if the 350 was origional to the car.....
Old Apr 7, 2008 | 05:15 PM
USALT1's Avatar
USALT1
If these are double hump heads, that date code is probably for '69, I dont think they made camel hump heads much after 1970. Are they angle plug heads? The 3973370 were available over the counter with straight or angle plugs.
To Need 350 Cylinder Head Information
