RPM's
Old Apr 6, 2008 | 08:51 PM
brazky75's Avatar
brazky75
Default RPM's
I have a stock L-48 75 went for a drive today and noticed that at 55-58 mph the tach read 3700-3800 rpm is this about right for 308 gears and a th400. I drove on the interstate last year at a steady 65 to 75 and seem okay but I hadn't fixed my tach yet so I don't now what the rpm's are at those speeds. Don't know why I didn't try higher speed but it seem like it was kind of tight for only 55mph.
Old Apr 6, 2008 | 09:41 PM
'75's Avatar
'75
that sounds kind of high, you sure it was in hi gear? Sounds like the tach is wrong or else the trans didn't shift into 3rd.
Old Apr 6, 2008 | 09:46 PM
BritewhiteC3's Avatar
BritewhiteC3
Seems high...
My 75 W/th400 and 308 gears turns about 2700-2800 at 70MPH
Old Apr 6, 2008 | 09:59 PM
brazky75's Avatar
brazky75
I have had trouble with the shifter going into second when I thouht it was in drive and have had to push it up like a half a click to get into drive. If it's not raining tomarrow I'll take it for a spin and check it out. By the way is there a fix to the shifter problem I'm having.
Old Apr 7, 2008 | 08:37 AM
yel76low's Avatar
yel76low
No way that's right. Way, way high.
2nd gear is 1.48, right? Stock tires, 3.08 rear, and 1.48 transmission gives you 3243rpm @ 58mph. You sure you have 3.08? Same setup with 3.73 rear gears gives 3928rpm @ 58mph.
Old Apr 7, 2008 | 10:04 AM
wiseman79's Avatar
wiseman79
That will vary with tire size, also does that account for trans slip which would occur since it's not a lockup trans? Definitely sounds like you're in 2nd, with 3.08's and 255/60's I'm at about 2200 at 60 if I remember right.
Old Apr 7, 2008 | 10:16 AM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
I agree with the above answers, way too high for 3.08 gears. Our 79 has 4.56 gears, and turns about 3600 rpm around 70 mph with a automatic.
Old Feb 15, 2009 | 10:05 AM
kansas123's Avatar
kansas123
Originally Posted by BritewhiteC3
Seems high...
Same for my '72, 350, TH400, 3.08 gears
Old Feb 15, 2009 | 01:44 PM
Sweet's Avatar
Sweet
I have 3.08 rear and this is what I get in 4th gear
50 MPH....2100 RPM
60 MPH....2600 RPM
70 MPH....2900 RPM
75 MPH....3100 RPM
To RPM's
