Marine grease
Old Apr 7, 2008 | 09:01 AM
Fscott's Avatar
Fscott
Default Marine grease
I'm getting differing opinions on marine grease. I was told I should use this on the Poly bushings I've installed but not on other applications...u-joints etc. It seems to me that this would also be ideal in that application...anyone have any thoughts on this?
Old Apr 7, 2008 | 09:34 AM
auctionman256's Avatar
auctionman256
i don't know i would use it.
Old Apr 7, 2008 | 11:01 AM
noonie's Avatar
noonie
Marine grease is generally better than regular.
The best grease is with the highest content moly-d you can find.
It will be an EP grease with far superior stickyness, high temp, water resistance, and lube quality.
For example, this type of grease is used in high dollar, deep mining machines in wet, dirty conditions, both on bearings and sliding surfaces.
Just google for some locally.
Old Apr 7, 2008 | 12:40 PM
Fscott's Avatar
Fscott
thanks guys
I think I'll have to go with the marine grease.
Old Apr 7, 2008 | 03:18 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
A primary quality you're looking for when lubricating poly bushings is a grease that resists wash-out, so marine grade and/or synthetics with that quality are very well suited. I believe Energy Suspension packages a grease for this application, as well.
Old Apr 7, 2008 | 03:31 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I like the ES grease, it's not all that expensive when you consider the time to disassemble and re-grease everything.
Old Apr 8, 2008 | 08:26 AM
Fscott's Avatar
Fscott
thanks guys!
To Marine grease
