clutch pedal adjustment
Old Apr 7, 2008 | 10:56 AM
kyeakel's Avatar
kyeakel
Default clutch pedal adjustment
After a search, I didn't find an answer to this question. I have only a small amount of disengagement of the clutch right at the bottom of the pedal travel. I see from the search that I can get an adjustable pivot ball for the bellhousing. However, the z-bar has 2 holes in the half that connects to the pedal. I'm currently in the upper hole with the pedal rod rotated to the upward position. If I flip the rod, it will (I think) fit into the lower hole. This should increase the distance that the clutch arm travels. The setup I have is ST-10 with aluminum bellhousing, stock style pressure plate and disc.
Anyone have any thoughts on this?
Kipp
Old Apr 7, 2008 | 08:43 PM
CCrane65's Avatar
CCrane65
Kip, have you already exhausted all of the threads on your clutch rod? Very little movement of the pivot makes for a large difference in clutch release.
cc
Old Apr 8, 2008 | 07:40 AM
kyeakel's Avatar
kyeakel
Yes, I'm at the end of travel on the clutch rod. Since this is a new setup, I'm guessing I bought the wrong length throw-out bearing. The only other possibility is that I have the wrong z-bar or clutch fork. Since I don't know what the various z-bars measure, I can't tell. Same goes for the fork.
Kipp
Old Apr 8, 2008 | 02:43 PM
tyancey00's Avatar
tyancey00
I just adjusted mine where it comes through the fire wall. In the engine bay. I was on the floor and it is now just right for me.
Old Apr 8, 2008 | 08:33 PM
kyeakel's Avatar
kyeakel
Well I just flipped the clutch rod over and attached it to the lower hole on the z-bar. Pedal is a bit stiffer but the travel seems normal. The disengage point is now at about middle of the pedal travel.
Kipp
Old Apr 8, 2008 | 08:53 PM
BTAL's Avatar
BTAL
St. Jude Donor '09
To piggy back here on a related issue. Does your clutch pedal set much higher (closer to you) than the brake? Supposedly there is a clutch bumper pad that is on the inside of the car at the top of the pedal, but for the life of me, I can't get contorted enough to see where it should mount.
Old Apr 8, 2008 | 09:01 PM
blckslvr79's Avatar
blckslvr79
Every one I've talked to and everything I've read says the clutch pedal is suppose to sit about an inch higher than the brake pedal. Seems strange to me and kind of awkward at first, but that's what I've found.
Anybody else have different experiences????
Old Apr 8, 2008 | 09:10 PM
BTAL's Avatar
BTAL
St. Jude Donor '09
There's a post by pbcanney - http://forums.corvetteforum.com/show...h+pedal+bumper
That gives some info and initially took me down the research path. Zip-products have the on their site for about $3
Old Apr 9, 2008 | 07:19 AM
kyeakel's Avatar
kyeakel
My pedal does sit about 1" higher than the brake pedal. Unless my memory is fading, most of the 60's and 70's cars I've driven have had this arraingement. My setup has new (probably remanufactured) pedals and new bumpers. Now that the automatic is gone, the car runs like I'd expect a vette, or any muscle car to run. Tires can be spun at will, and it's not difficult to get multiple gear rubber.
Kipp
To clutch pedal adjustment
