Key question
Old Apr 7, 2008 | 12:46 PM
NUCCI's Avatar
NUCCI
Default Key question
I've resently bought a 1976 vette that the owner lost the keys too.I have replaced the ignition cylinder and key,all I need now is to get a door key made.My question is does the spare tire lock and side fender lock take the same key.It would be alot easier to remove the side fender lock than the door lock.By the way I'm assuming the fender lock is an alarm of some sort.Thanks guys.
Old Apr 7, 2008 | 12:48 PM
S489's Avatar
S489
square - ignition
round - all others
Old Apr 7, 2008 | 04:55 PM
pacrimmat's Avatar
pacrimmat
In my 76' there are 3 keys. ignition, door and the alarm in the lft frt fender. (alarm horn is up and under lft rear fender)
Old Apr 7, 2008 | 08:55 PM
NUCCI's Avatar
NUCCI
Default Key Question
Thanks for the reply and help.The rear compartment door that has a lock behide the seats is that the same as the door key?Trying to get a key made for the doors but those locks look difficult to remove.Thanks.
Old Apr 7, 2008 | 10:29 PM
S489's Avatar
S489
yes, you can get replacement cylinders that either you can make match you existing key or you can have someone else do this.
cylinder is easy to remove
To Key question
