shinning alumunum wheels
Old Apr 7, 2008 | 03:52 PM
chromerican's Avatar
chromerican
6th Gear
Default shinning alumunum wheels
Hi everyone, I just shine the original wheels of my vette, but they were too damaged, they looks very nice at the moment, the problem is that the clear protection to the metal was removed. what kind of clear paint is used to preserve the metal against the stains? If somebody know please tell me. Thanks
Old Apr 7, 2008 | 04:06 PM
marshrat99's Avatar
marshrat99
The finish is a clear coat. I've seen a refinish kit on Mid America Design's site. Would probably be a good idea to refinish but I'm just repolishing ever so often with Mothers. I find that Mothers is a little less abrasive than Never Dull.
Old Apr 7, 2008 | 04:30 PM
Belgian1979vette's Avatar
Belgian1979vette
I just leave my wheels polished without clear. Clear will be hit with rocks and the aluminum will start to corrode again underneath. You will have to polish it from time to time.
Old Apr 7, 2008 | 04:36 PM
Roughrider's Avatar
Roughrider
Meguair's and Griot's each have mag wheel polish made specifically for alloy wheels. I've used both on wheels and polished aluminum valve covers and both are excellent.
Old Apr 7, 2008 | 10:15 PM
chromerican
6th Gear
Thanks A Lot!!
Old Apr 9, 2008 | 03:36 PM
WillEE's Avatar
WillEE
What's the best way to remove the original clear coat?
I like the idea of leaving bare and polishing.
Thanks,
Old Apr 9, 2008 | 03:51 PM
gleninsandiego's Avatar
gleninsandiego
I used EZ Off Oven Cleaner after it was suggested by members here.
It took several applications and some elbow grease but it took everything off of those wheels. I then took them to a professional wheel polisher, who had a polishing machine, and they came out looking like chrome.
Old Apr 9, 2008 | 04:01 PM
marshrat99's Avatar
marshrat99
Thanks,
I sanded mine. A brief soak of paint stripper might be easier.
Old Apr 9, 2008 | 06:30 PM
milo30's Avatar
milo30
I just bought the Mothers attachment for my drill and tried it on my wheels....I'm impressed. I have never seen the wheels shine so much. I wish I had of had one of these things years ago.
Old Apr 9, 2008 | 06:40 PM
VIPERBARON's Avatar
VIPERBARON
From: Guantanamo Bay, Cuba (home in Colorado Springs)
Yup, what I did. Works great. It's called "Powerball". Little red foam feather ball that fits on a drill and comes with a can of polish. Makes a mess, but cleans up nicely.
Old Apr 9, 2008 | 06:43 PM
shaggyvette's Avatar
shaggyvette
St. Jude Donor '10-'11-'12, '19, '21
I sanded mine with a fine paper then used Aircraft Stripper. Wash them down scrub with fine steel wool and use Mothers then Nevr Dull. It's a long process but they come up like new. When done I polish with a good carnuba wax. They are good for a couple of months.
Hope this helps....
Old Apr 10, 2008 | 10:02 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Hope this helps....
Are your wheels the original dull aluminum type (1976 vintage) so to speak or the newer shinny (chrome?) ones.
Old Apr 10, 2008 | 08:39 PM
chromerican
6th Gear
Hi, I used water sand paper 600 grid, then 1000 grid and then with 2000 grid, the last job I scrub with steel wool, after thet I used mothers polish. It looks like new, the benefits to sand paper is that you can correct the imperfections on the metal, while remove the opaque clear and shines at the same time.
Old Apr 11, 2008 | 01:25 AM
Theiskell's Avatar
Theiskell
That is how the pro's do it
Old Apr 11, 2008 | 12:03 PM
shaggyvette
Jud, they came off a 79. They were all cloudy and dull when I got them off e-bay. I can make them look just like chrome in 1/2 hour with the Mother's Ball and my cordless drill.
Dave
Old Apr 14, 2008 | 08:06 AM
Jud Chapin's Avatar
Jud Chapin
Dave
Thanks, Dave. I'll give it a try.
Old Apr 14, 2008 | 10:25 AM
wro87's Avatar
wro87
On the 80' we had after striping the clear off (not much left) used some fine steel wool to clean up the oxidation. Then used my big Milwalkee poliser with a new lambs wool pad and mothers didn't take too long and looked liked chrome just had to be a little carefull around the valve stem which we did by hand. Infact used two pads one to clean and one to polish, then used the Wenoil wax to coat them. Makes them easier to clean next time and even less time.
wro87
Old Apr 14, 2008 | 10:04 PM
OldCorvetteKid's Avatar
OldCorvetteKid
Try "Blue Magic"...with the power ball...worked better than "Mothers" for me.
To shinning alumunum wheels
