I have a recently built modified L-82. It starts right up when it’s cold but after I drive it and then try and restart it it acts like it’s not getting any fuel. It turns over and over about 3-4 times longer than it does when it’s cold and then finally starts. I talked to a local guy that build a lot of race engines and he said that it sounds like “The hard starting may be fuel boil out, engine is hot when you kill it, and it evaporates the gas in the bowls.” He said that if I switched out to an electric pump it should eliminate this. Does this sound right?
Could be correct, You need fuel to have ignition. Appears you have a very good starter to be able repeatedly crank it for up to four times longer than when cold. Vapor lock is another name for the fuel starvation issue present more often when hot. Common among AC equipped cars with out the third return line.
I have the same problem starts fine when cold and if i shut if off and try right away it fires up , but when its been running awhile and i let it sit for more than say five min. it cranks a few times before starting .
I too thought it was because of the heat in the bay ,maybe a spacer on the carb base would help a little ?
Yes that sounds right. Your starter is cranking ok...right?
I just added an electric pump, back by the tank,that I use for just such reasons and to fill the bowls after storage. I used a Holly pump that the mechanical pump can draw fuel through. That way I only turn it on when needed. Been working just fine for more than twenty years.
Okay I mis-read. I thought you were saying it was having trouble cranking, and a revolution was taking 3 or 4 times longer than when cold. You mean it cranks normally, just longer.
The next time you have this issue have somebody, if you can, look into the carb, pump the gas a couple of times. If gas shoots into the carb from the nozzles, the bowls have gas in them. If this happens, crank it over and it should fire right up. If you get no gas then there's none in the bowls and you've confirmed this issue. If you get gas into carb from nozzles and it still wont start, probably not a fuel issue.
Hey JP is your ride using alot of gas , mine seems to be getting sum realy ****ty gas milage , i wonder if its due to the vapor lock like Ironcross said .
The carb is probably empty. Probably a heat/fuel issue. You can try to diagnose this by warming up the car, shut it down, wait long enough to recreate the problem and pour some gas into the bowls right before you try to restart it. If it starts easy, you probably had empty fuel bowls.
Check to see if the heat riser valve is stuck closed. If you have an aluminum intake you might want to get rid of the heat riser and block the drivers side heat pasage in the intake. I use a thin strip of stainless steel sheet metal between the 2 center intake bolts on the intake gasket to block the passage off. I would look for some very thin stainless steel sheet metal or just cut up a piece from one of your stainless steel kitchen bowls that has a large flat bottom. I have some dimensions if you need them just PM me.
If it is a Q-jet you might benefit from a different fuel filter element. There are filters both with and without the anti backflow valve on them. In some situations you might be better off with the anti backflow filter element. That would be a long shot here.
I thought about that but I already have a 2" raised Weiand Team G Intake. I could be wrong but I thought that would be high enough.
Yes start is cranking great, just seems fuel starved. Am I reading this right and you are running both pumps (elec and mech)? But just use the elec to fill the bowls after storage.
Yep, I was wrong, probably not the starter.
No problem, I probably could have discribed it a little better. All ideas and advise are appreciated.
Yes, it burns the hell out of gas. But that was expected when I had it built. But I'm sure it boiling out the bowls (if that is what it is) is not helping!!!!
That is correct. I have left it on without knowing. Never had a problem, both on, electric off....runs the same. Sure saves allot of cranking in the spring. I turn it on and listen to the motor...you can tell when the bowls are full. Then a couple cranks and its running.
That's how my electric pump is. It's a bellows style pump, that actually stops pumping when the pressure in the fuel line tells the pump that the bowls are full. I can turn it on, prime the carb, and then his start and it takes a lot less cranking to get it started.
