My 68 "barnfind" (PICS)
Old Apr 8, 2008 | 03:28 AM
Ronaldo's Avatar
Ronaldo
Default My 68 "barnfind" (PICS)
Sorry, that post should have been in C3 generel section, I have moved it :o
http://forums.corvetteforum.com/show....php?t=1991028
But I do have a related tech question. The oil pressure gauge goes off the scale (over 70 psi) when it idles. Is this likely a problem with the oil pressure gauge, or something wrong with engine?
Old Apr 8, 2008 | 07:10 AM
1982CorvetteDude's Avatar
1982CorvetteDude
It's possible you could have one of those melling HV oil pumps in your engine. I installed one in mine and it pegs over to the right side of the guage too........i would check that first.
Old Apr 8, 2008 | 11:03 AM
Solid LT1's Avatar
Solid LT1
If the Vette has been sitting for extended periods of time, the oil pump pressure relief valve may be gummed up and sticking. First step would be to put another guage on the fitting by the distributor and get a second opinion from another pressure guage. Oil pan drops easily when you pull the steering idler arm off the frame. Looks like a nice find!
Old Apr 8, 2008 | 11:17 AM
madmax_mfp's Avatar
madmax_mfp
Very nice find. Yes the steering wheel is incorrect. It looks like it has a tilt column which is also incorrect(for 1968). I have been going over my 1968 "barn find" for a couple of years now and it looks to be completely origin less paint.
Old Apr 9, 2008 | 02:47 AM
Ronaldo's Avatar
Ronaldo
Thanks... I have looked under the bottom, it does not look like the engine has been opened or the oil pan has been off, so I would be surprised if it has a HV melling pump. I have drained the oil from the engine, that oil was many years old
The steering wheel is not original but the PO still has the original (wood or wood-like) steering wheel, I will get it when he finds it.
Its not a tilt column but just a telescopic column. That was an option in 1968, was it not?
Old Apr 10, 2008 | 11:18 AM
Ronaldo's Avatar
Ronaldo
I have changed the oil and tried to run the engine (on the starter) with no valve on.
There is not coming any oil to the top... Any ideas what to do next?
To My 68 "barnfind" (PICS)
