Carb question
Old Apr 8, 2008 | 09:50 AM
rayluka's Avatar
rayluka
Default Carb question
While running a WOT I was experiencing a surge. I was told this was probably due to a lean setting of the carb. I plan to send it off to Lars if he stays in the "business" after his recovery. But this weekend while on a cruise I accelerated onto the freeway and experienced a feeling of just plain running out of fuel. I took my foot out of it and it would recover. Any ideas, maybe bad float setting????
Stock L-48 q jet
Old Apr 8, 2008 | 10:12 AM
justanotherdoe's Avatar
justanotherdoe
If you can't get a lars rebuild, using a lars paper to do your own rebuild is the next best thing:
http://www.corvettefaq.com/c3/QJetTuningPaper.doc
Get a rebuild kit, take your time and follow the instructions in the paper. I did this with a used q-jet I got from e-bay. Maybe it's not as good as the master could have done but it fires right up, no bogs or dead spots, runs strong and gets me to/from work every day.
Old Apr 8, 2008 | 10:22 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Have you changed the fuel filter?
Old Apr 8, 2008 | 11:12 AM
rayluka's Avatar
rayluka
Thanks. Will do some reading....and change the filter
Old Apr 10, 2008 | 11:34 AM
rayluka's Avatar
rayluka
fuel line is bubbafied. Ordered new line from pump and fitting in carb. WIll post results
To Carb question
