Caliper leaking
Old Apr 8, 2008 | 03:07 PM
Dante7's Avatar
Dante7
Default Caliper leaking
Well my calipers were just rebuilt recently and all the seals look great but when I was replacing the pads the other day i made the mistake of allowing one of the pistons come out of the bore. I tried to just push it back in but tore the one lip seal. So I went out and bought a rebuild kit and figured I would just replace the one since the others were new and that way I would have a second try at things if it leaked again.. Well needless to say i put the new seals on it tried to push it in again and it leaked the bored looks absolutly perfect so what am I doing wrong here beside everything? 75 L-82 Vette
Old Apr 8, 2008 | 09:57 PM
Scott Marzahl's Avatar
Scott Marzahl
THis is kind of hard to explain but did you make sure that the piston seal's lip was inserted facing into the bore and not outward which would allow fluid to get by it?
