Torque Question
Old Apr 9, 2008 | 01:45 PM
Desert68's Avatar
Desert68
Default Torque Question
I have a couple questions about torque and torque ratings. Is torque multiplied when it’s transferred through a set of gears? For example, engine makes 400 ft lbs of torque, transmission is in a 1:1 gear and the rearend has a 3.90 gear. Is the 400 ft lbs multiplied by 3.90 so you are putting effectively 1560 ft lbs to the ground?
If a transmission has a certain torque rating, does that rating vary as the first gear ratio changes?
Old Apr 9, 2008 | 03:17 PM
Belgian1979vette's Avatar
Belgian1979vette
The first is correct.
The torque rating of any trans is relative. The torque it can withstand is dependant on different aspects and not just the torque multiplication of the gears.
Old Apr 9, 2008 | 04:04 PM
sethjohnson71's Avatar
sethjohnson71
That is incorrect. You actually lose a large fraction of your power through the trans and then on through the rear end too. That's why horsepower and torque ratings are less at the rear wheels than they are at the flywheel. Your rear end gears determine how many revolutions of the driveshaft make one revolution of the wheels. So a 3.90 would take 3.9 revolutions of the driveshaft for the half shafts (thus the rear wheels) to rotate once. With a higher numerical gear, the engine would be at a higher rpm at a given MPH, so probably making more power at a lower vehicle speed. Basically the gearing just determines engine rpm versus vehicle speed.
Old Apr 9, 2008 | 09:21 PM
OzzyTom's Avatar
OzzyTom
There is a lot of misunderstanding with rear wheel torque.
especially with data from dynos....
I read a recent post from our Australian LS1 forum, with a very good technical explanation on how dyno systems operate to provide the data displayed and provided to the customer.
Worth a read. rear wheel torque is very dependant on gear ratio, diff ratio, tyre size AND dyno roller radius.
http://www.ls1.com.au/forum/showthre...53#post1194753
Old Apr 10, 2008 | 03:17 PM
RespondsWithGif's Avatar
RespondsWithGif
Yep, that is the whole purpose of a gear reduction system. Torque multiplication.
To Torque Question
