Timing tab on '72 SB
Old Apr 10, 2008 | 07:09 PM
kansas123's Avatar
kansas123
Default Timing tab on '72 SB
The timing tab on my '72 SB has enough overspray on it to make the tab unreadable. The picture below is the style I have, and after installing my rebuilt stock distributor, I timed (with the vacuum unhooked and plugged, car at warmed up idle) it so that the mark came around to the center of the round cutout; it sounds pretty darn good there. Is that 12 degrees? I am afraid that if each tooth peak is 4 degrees, then setting the timing according to that will not the let the engine run at all (I guess I could have tried it anyways). I was using a borrowed trusty Sears timing light, old style. Thanks.[IMG][/IMG]
Old Apr 10, 2008 | 07:34 PM
72LS1Vette's Avatar
72LS1Vette
Here's a pic of a 72 timing tab.
Rick B.
Old Apr 10, 2008 | 07:37 PM
kansas123's Avatar
kansas123
Thanks Rick, now it's back to the light..................
Old Apr 12, 2008 | 06:16 PM
kansas123's Avatar
kansas123
Default Runs like a top!
Thanks again for the picture, timed to 12 degrees, runs like a top! And a BIG thanks to Lars for the outstanding rebuild, now it 's on to the carburetor, with a short stop first at reclocking the distributor so that the tach cable lines up better.
To Timing tab on '72 SB
