Heater electrical system troubleshooting
Thanks in advance, TheMongoose
Sequence of events:
Verified all black wires are hooked to the ground post on the starter.
Found the 25a fuse in the fuse block blown today but not the fuse in the engine bay. replaced the fuse box fuse.
Pulled the fuse out of the engine bay, turned the key on, checked for voltage. no voltage showing. verified voltmeter worked on a D-cell battery. During all the testing I did today this fuse never had power to it? I don't understand this?
pulled the connection at the relay (or whatever's in this aluminum colored box at the top of the above pic). realized this was the wrong set of wires to pull 1st, wanted to pull the power from the blower motor 1st. noticed smoke coming from the blower motor area. smelled burning wiring. turned key off.
located the power wire (purple) and the ground for the blower motor. found the ground very loose. tightened & relocated ground to a different screw on the case. turned key on. Now the fan runs at low speed and there's no more smoke. All this was done with the fan switch in the off position. the a/C controls were set on norm A/c then bi-lvl then vent and it ran at slow speed on all these.
turned on the fan switch and it worked at all speeds.
Started the car, moved the controls to heat so I could see if this would work now. everything stopped working. No power at blower motor now. found the fuse in the car blown again and the fuse in the engine bay was fine.
Out of fuses so I will work on this again after I get some more advice and then run to AdvanceAuto for a pack of fuses.
If you can give me a few clues as to how to proceed I'd be grateful.
From your description it sounds like the bearing in the motor is gone, binding the motor and making it run slow and draw high current. Pull the motor out and see if you can lube the bearings or replace it. they are not expensive.
The black ground wire from the blower ends up in the wiring going behind the distributor with a bunch of other wires all taped together. It doesn't look like it goes near the starter but everything is all taped up. The black wire off the solenoid goes up next to the engine and then looks like it goes thru the firewall with another group of taped up wires.
