Using Big Block motor mounts on a small block?
Old Apr 11, 2008 | 01:53 PM
Hadez's Avatar
Hadez
Default Using Big Block motor mounts on a small block?
Is it possible to use big block motor mounts on a small block? I heard this will drop the engine down a tad further helping with driveline angles when doing a 5 or 6 speed swap? This would be for a stock 69 vette.
Old Apr 11, 2008 | 03:21 PM
wombvette's Avatar
wombvette
Motor mounts are the same.
Old Apr 11, 2008 | 05:13 PM
RHD '68 L89's Avatar
RHD '68 L89
In fact, BB's have a spacer in between the mount and block to raise the motor a touch higher, or maybe to make it work with the SB mounts...
To Using Big Block motor mounts on a small block?
