Electrical nightmare?
Old Apr 11, 2008 | 10:09 PM
Dantana's Avatar
Dantana
Default Electrical nightmare?
I went out to fire up the car today for the first time since November. It started right up (after a battery charge) and then nothing. Waited 30 minutes, fired up for about 20 sec and then dead again. 1 more time, same thing. I grabbed a few wires and one of the smaller guage wires (not sure where it goes but not B+) on the back of the alternator snapped in my hand. I spliced in a new section with connectors to try and quick diagnose and nothing. Carb is definitely squirting gas so i don't think fuel problem. Pulled #4 plug and it looked fine. If I connect the plug to the wire and turnt he car over shouldn't it spark? I tried in with the plug in air and also touching various surfaces for ground. No spark.
Ideas?
Old Apr 11, 2008 | 10:22 PM
wombvette's Avatar
wombvette
Go to the coil and check for power on the positive side when the key is on. Or, you might want to use a clip lead and pickup 12V off of the alternator or battery to the positive side of the coil. If it starts and runs, you need to find the bad wire that feeds the coil from the switch or to the switch.
Old Apr 12, 2008 | 01:07 AM
Dantana's Avatar
Dantana
Ok I got out my voltmeter and I picked up 12V between the alternator and the coil on this MSD system so I think the wires are good. Should I have seen a spark on that #4 plug when I pulled it?
Could this be a choke problem also maybe? Car worked perfect when i put it away severl months ago. Only thing I redid was the brake system.
Old Apr 12, 2008 | 10:06 AM
jnb5101's Avatar
jnb5101
are you saying that the car runs for about 30 seconds and then dies? if this is the case, you're getting spark. i'd check the fuel filter first, then fuel pump.
jeff
Old Apr 12, 2008 | 10:22 AM
Dantana's Avatar
Dantana
Exactly Jeff, runs then dies - and runs w/o missing from the sound of it.
If it was fuel pump or filter would the bowls in the Holley be empty when it dies? Mine are not empty.
Fuel filter is not completely clean but fuel appears to be passing through it. I was planning to replace shortly, I can do today. Haven't checked the pump yet.
Old Apr 12, 2008 | 10:31 AM
jnb5101's Avatar
jnb5101
i would say that you're just getting enough fuel to start and run for a short time because of low fuel pressure, clogged filter, or possibly improper float level. i'd start with the easiest-filter. it's also possible that the float is stuck, and you're getting too much gas. does it smell like it's flooded after it dies?
jeff
Old Apr 12, 2008 | 10:38 AM
wombvette's Avatar
wombvette
Default If People Would Only
State in their question just what they have, and precisely what the symptoms are, they might get better answers. This one for instance, didnt have what year nor that it was converted to Electronic, or a clear description of symptoms. I, being and old fart with a bad attitude,
dont want to go hunting up the information in your damn profile. Is that too much to ask?
Old Apr 12, 2008 | 10:57 PM
Dantana's Avatar
Dantana
jeff
Yes Jeff, smells like gas when dies. I'll got through the fuel system. Thanks.
Old Apr 12, 2008 | 11:27 PM
'75's Avatar
'75
You should be getting spark on the plug that's removed by grounding the plug while you crank it over.
Old Apr 13, 2008 | 12:45 AM
wombvette's Avatar
wombvette
Originally Posted by Dantana
Screw off. How are you helping? Go watch a rerun of some movie from the 40's on AMC.
OOH, Someone else has a bad attitude. I tried to help earlier,
"Go to the coil and check for power on the positive side when the key is on. Or, you might want to use a clip lead and pickup 12V off of the alternator or battery to the positive side of the coil. If it starts and runs, you need to find the bad wire that feeds the coil from the switch or to the switch. "
But you through us a curve ball by not stating even the most basic facts, and didnt tell us of the changes. It makes a lot of difference if it has electronic mods.
Good luck with your problem.
Old Apr 13, 2008 | 10:34 AM
Dantana's Avatar
Dantana
I've doen some research on this MSD system and I have come to learn that the boxes and other parts are tempermental. I got it going again yesterday and then no spark again.
Does anyone have experience with their MSD systems failing? I've not had one before this car. I've previously had HEI's and they seemed bullet proof.
Old Apr 23, 2008 | 11:49 PM
sperkins's Avatar
sperkins
Are you absolutely sure your ignition is failing and causing the engine to die? Does it choke down and stall or does it kill itself immediately?
Try hooking up a timing light and watch it while the engine dies. If the light suddenly goes out, then you obviously have a spark problem.
It could be something as simple as the needle and seat sticking after being stored for a while which would screw up your idle circuit. If that's the case, the accelerator pump will indeed squirt fuel, but that doesn't have anything to do with the float level or the idle circuit. No gas in the bowl = dead engine.
Old Apr 24, 2008 | 06:31 PM
Dantana's Avatar
Dantana
It chokes down and stalls. I'll try the timing light and see where it leads. Thanks.
Old Apr 24, 2008 | 06:49 PM
mrvette's Avatar
mrvette
WHICH is a classic example of just perZactly why so many guys who know this stuff like the back of their hands.....
don't post so much anymore.....
the 'tudes' are getting deep guys, and frankly I feel free to say so, as ME and MANY others are tired of the which runs FAR and DEEP in especially the electrical/tronic side of things....
much less others on the mechanicals.....
I hate saying this, really do , after some ten years here, BUT it's a huge letdown....
case closed....
Old Apr 24, 2008 | 07:50 PM
SmokinBBC's Avatar
SmokinBBC
Some guys don't appreciate FREE knowledgable help...
case closed....
You got that right
Old Apr 24, 2008 | 08:16 PM
ctk30's Avatar
ctk30
Excellent way to get help
To Electrical nightmare?
