tapping/slapping noise
Old Apr 12, 2008 | 10:39 PM
cruise83's Avatar
cruise83
Default tapping/slapping noise
I have a tapping/slapping noise from the front of my 5.7L 350 in my 79. I have ruled out a valve tap for now. Can my timing chain be hitting its cover? If so can it be adjusted? Do the chains stretch over time a get loose? the noise apprears after 1500 RPM.
Old Apr 12, 2008 | 11:47 PM
PeteZO6's Avatar
PeteZO6
The OEM sprocket on the cam had nylon teeth which can come off in chunks. If it does you will hear a ticking or clacking coming from that area. You can localize the noise by using a piece of hose or a long screwdriver and with one end near your ear, put the other on the timing cover. Be very careful around the fan!!!!!!
If that is the problem, a new timing set is in order. Best bet is a double row true roller.
Cheers,
Pete
Old Apr 13, 2008 | 01:33 AM
marshrat99's Avatar
marshrat99
Fig A for me would be the fuel pump believe it or not if you've not done anything recently to your engine.
Old Apr 13, 2008 | 08:22 AM
SIXFOOTER's Avatar
SIXFOOTER
Check for exhaust leak before ripping the thing apart, will sound just like what you describe
Old Apr 13, 2008 | 10:48 AM
cruise83's Avatar
cruise83
thank you forum, now I have at least three trouble shooting tasks I can try. That's the fun of it, right...
Old Apr 13, 2008 | 10:55 AM
Ganey's Avatar
Ganey
A worn fuel pump pushrod can make a tap like valve tap. Said to be "impossible" to find.
Old Apr 17, 2008 | 11:35 PM
cruise83's Avatar
cruise83
Default problem solved by fuel pump
just want you to know I replaced the fuel pump and the noise went away. glad I did not tare into the timing chain and gear. Thanks forum.
Old Apr 18, 2008 | 03:55 PM
PeteZO6's Avatar
PeteZO6
Me too! Always check the easiest first. I had the cam sprocket failure, but not the fuel pump push rod problem.
Cheers,
Pete
Old Apr 18, 2008 | 11:47 PM
cruise83's Avatar
cruise83
Default one last issue a crimped furl line
see the picture, does anyone have pics about how to connect the fuel line to the pump?? Mine is crimping...
Old Apr 18, 2008 | 11:51 PM
cruise83's Avatar
cruise83
by the way, I needed to turn the ignition a couple of times to turn the cam shaft so the fuel pump rod could depress far enough to allow the fuel pump arm to insert into the proper position. Several of the books and manuals I had did not discuss this step. Using vaseline to hold the rod in place did help,
Old Apr 19, 2008 | 06:57 AM
cruise83's Avatar
cruise83
anyone have a picture or solution keep the fuel line from crimping?
Old Apr 19, 2008 | 07:18 AM
Ganey's Avatar
Ganey
Several.
Formed hose, routing & length, fitting to pump at correct angle & also a hose clamp can be used to hold hose open.
To tapping/slapping noise
