do i have a 454???
Old Apr 14, 2008 | 03:10 PM
joshtried's Avatar
joshtried
St. Jude Donor '08-'09-'10
Default do i have a 454???
i cannot see any numbers on the block.. so i cannot eliminate it that way.. what i do know is the altenator and ac and stuff dont look like those i have seen on other 350's
on top of that, i have a haynes manual and was reading about power steering pump removal which i just did.. it says i have to remove the alternator brackets and stuff in order to remove the PS pump if it is a 454. with 350, im just supposed to be able to remove the bolts and go..
i guess what im askin is, on a 350, (79 vin/80 front end) does the alternator sit on the driver side, directly above the PS pump, where you kinda have to fanagle the PS cap off to fill it.. and does the AC sit on the passenger side? or do i have a 454 sittin in my engine compartment, all unaware of it?
would a 454 sit in there and me not know the difference? i thought 454 were pretty big in comparison..
am i crazy???
Old Apr 14, 2008 | 03:15 PM
Durango_Boy's Avatar
Durango_Boy
Can you post a picture of it or give us the numbers off of the number pad, just in front of where the passenger head sits on the block?
Old Apr 14, 2008 | 03:16 PM
pbcanney's Avatar
pbcanney
real fast answer
350 has 4 bolts per valve cover
454 has 7 per cover
350 has exhaust ports together in middle, equal space on 454
IE:
350 O_OO_O
454 O_O_O_O
Old Apr 14, 2008 | 03:20 PM
joshtried's Avatar
joshtried
damn... guess im a 350... that exhaust port thing is an awesome and REALLY quick way to tell
Old Apr 14, 2008 | 04:05 PM
Crash80's Avatar
Crash80
That sounds exactly like the 350 sitting in my '80.....
Old Apr 14, 2008 | 05:02 PM
Durango_Boy
That's an easy fix. Pull the engine, and sell it. Buy a GenV or GenVI 454 from a truck or SUV and slap a carb manifold on it. They are roller engines. Change the cam, widen the exhaust, and spin the wheels to elongate your smile.
Old Apr 14, 2008 | 06:35 PM
BigBlockk's Avatar
BigBlockk
If he can't tell a Small Block from a Big Block I think this is a little over his head.
BigBlockk
Later.....
Old Apr 14, 2008 | 08:43 PM
73-84 IMSA Widebody's Avatar
73-84 IMSA Widebody
HEHEHEHEHE>>>>>HEHEHEHEHE>>>>>HEHEHEHEHE HEHE
Old Apr 14, 2008 | 10:01 PM
joshtried's Avatar
joshtried
i can tell a big block from a small block, but when the book says one thing, and your looking at it....
anyways, i dont even think the engine is close to a 79... i think it a 68 (at least the power steering pump is) i found that out today when i went to swap 'em at autozone...
i really need to pull the ac and get the numbers off this thing
so ive got 79 vin#, with 80's front end, and a 68 power steering pump.. horray for me!
Old Apr 14, 2008 | 10:09 PM
400hp427vette's Avatar
400hp427vette
St. Jude Donor '09
Keep asking questions on this forum is doesn't matter what you know or dont most of us are here to help and exchange knowledge. There are alot of people here that have helped me in the short time I have been on this forum.
Old Apr 14, 2008 | 10:20 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
sometimes you just have to scan thru the remarks to find your answer. But as stated, most here are very helpful, glad you now know it's a 350ci
Old Apr 14, 2008 | 10:25 PM
joshtried's Avatar
joshtried
i know... im just poutin.. i found some #'s on the back of the block, and one on a ac bracket were the front tag is supposed to be but isnt..
front is 74007354
back is 3970 (blob) 10..
with 43 GM next to that..
ima look em up and see what me gots
Old Apr 14, 2008 | 10:26 PM
C7GrandSport's Avatar
C7GrandSport
This is what a 454 looks like...
Old Apr 14, 2008 | 10:29 PM
400hp427vette
St. Jude Donor '09
front is 74007354
the front number 74007354 does that match your vin?
Old Apr 15, 2008 | 09:25 AM
joshtried's Avatar
joshtried
i can absolutely not find the front pad. the front number i found was on a mounting bracket for the ac.. i work a 12 today, so when i get home tonight, ill take a look behind the distributor. ive got no tags or inspection, so i cant take it to the wash and degrease it, but ill find it (i hope)!!
on the front though.. its just not there. the motor was definately repainted, and they might have knocked it off.
Old Apr 15, 2008 | 09:30 AM
Belgian1979vette's Avatar
Belgian1979vette
The word big is pretty relative. A 5.7 liter is referred to as a "big" engine where i come from, a 454 ? Well i guess that would be called a monster engine...
Don't laugh at him, when I saw my first vette, i had to look very good to make out the difference, but finally the exhaust port spread is a real easy way.
Old Apr 15, 2008 | 12:27 PM
Steve20's Avatar
Steve20
an easier way to tell-floor it you'll know if it's a 350 or 454 in 30 feet
To do i have a 454???
Old Apr 15, 2008 | 01:57 PM
CCrane65's Avatar
CCrane65
The pad is part of the block. It can't be knocked off. It is just in front of the passenger side head. It is a flat spot with numbers and letters stamped into it...unless the block was decked in which case there may be nothing stamped there because they were shaved off.
cc
Old Apr 15, 2008 | 02:02 PM
joshtried's Avatar
joshtried
its been sitting in a garage not driven at all for at least 4 years.. so even a 454 would bog.. no to mention the previous owner did not know anything about tuning, or about mechanics in general.................. it helps to LOOK at a car once in a while.
Old Apr 15, 2008 | 02:28 PM
Durango_Boy
Here is the engine stamp pad as best as I can show in a picture. Picture yourself standing on the passenger side, leaning in over the fender, and looking down at the timing cover and water pump.
