speedo and tach question
Old Apr 14, 2008 | 08:48 PM
bonehead2's Avatar
bonehead2
Default speedo and tach question
Has anyone put later model speedo and tach say 73 in an earlier car , say 69.I need to use an electric tach in my 69 and do away with cable drive.I will buy a later electric set if they will fit correctly in the 69 dash.What year did they change to electric tach 73?.
Thanks for any info.
Old Apr 14, 2008 | 08:57 PM
wombvette's Avatar
wombvette
Change was in 75. I think it will work, but the color of the face numbers etc. are a little different. I actually put a `75 in my 66. But that required some serious fitting.
Old Apr 14, 2008 | 10:41 PM
chvet73's Avatar
chvet73
I replaced the original tach in my '73 with an electric from a '76 and it fit right in. Just had to wire it up and it'sworked fine since.
Old Apr 14, 2008 | 10:48 PM
Theiskell's Avatar
Theiskell
75 and 76 will work, but as stated before the numbers are white.
Old Apr 15, 2008 | 01:07 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The tach will work just fine, it a shame but you can't do a face swap on tachometers. The electronic face has a tighter pattern than the machanical face. You could swap out the green face speedo for a white faced one to make them match.
Old Apr 15, 2008 | 01:33 PM
bonehead2's Avatar
bonehead2
Thanks for the info. Any good sources to buy these 75 tach and matching speedo?.
To speedo and tach question
