oil pump shaft
Old Apr 15, 2008 | 08:54 AM
mdj21's Avatar
mdj21
Default oil pump shaft
looking down the hole that the distributer goes into and wiggling the oil pump shaft with a long screw driver, how much should it move from side to side or front to back?
mine moves almost 1/4". does this sound right to you guys?
Old Apr 15, 2008 | 09:10 AM
VIPERBARON's Avatar
VIPERBARON
From: Guantanamo Bay, Cuba (home in Colorado Springs)
Yes, it's ok. The dist shaft has a small collar on the end that keeps the oil pump shaft from wiggleing. That oil pump shaft has a similar collar on the end that splines into the oil pump.
Old Apr 15, 2008 | 09:58 AM
mdj21's Avatar
mdj21
thanks.....
Old Apr 15, 2008 | 02:27 PM
Aggitated Monkey's Avatar
Aggitated Monkey
Stock collars are nylon and you can purchase a new shaft that come with a steel collar. Not sure if it is needed, however it does provide a sence on security.
Check your collar for cracks as they do break apart easily as they become brittle from heat.
Old Apr 15, 2008 | 03:24 PM
mdj21's Avatar
mdj21
i'll check it, thanks.
To oil pump shaft
