Inner door handle (68-77)
Old Apr 15, 2008 | 07:03 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Default Inner door handle (68-77)
What's the proper procedure for installing a 68-77 door handle? I've never seen a thread on the subject, and the AIM is vague. Rotating the mechanism out enough to install the handle without a handle attached is difficult.
Old Apr 15, 2008 | 07:20 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Batman,
You are correct! You can use a flat blade screw driver to move the door opening mechanism outward enough to install the handle, then use the handle to hold it open and install the screw. That’s about the only way to do it.
Willcox Inc
Old Apr 15, 2008 | 07:40 PM
Durango_Boy's Avatar
Durango_Boy
Originally Posted by Willcox Corvette
Batman,
Willcox Inc
That's the way I have always done it.
A way I found to make it easier was to use an Allen screw the same size as the stock screw, so it can stay on the end of a driver easier while you try to start it. The Phillips screws keep falling off of even magnetic tip drivers, so I tried the Allens and liked the results.
Old Apr 15, 2008 | 07:57 PM
SpE3dF0x's Avatar
SpE3dF0x
interesting point...I was planning on doin' this but didn't see a post on this subject?
Old Apr 16, 2008 | 08:55 AM
vettfixr's Avatar
vettfixr
Or you could do what I did and break the original door handle mechanism and replace them.
Old Apr 16, 2008 | 11:25 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Batman,
Willcox Inc
Doing that has led to a rather jacked-up driver-side inner door latch assembly. Does anyone know how the factory put them together?
Also, what's the quality like on the repopped inner mechanism? My parts guy has both new ones and good used.
To Inner door handle (68-77)
