STRANGE STARTING HABITS (part 2)
Old Apr 16, 2008 | 05:42 AM
scott3392's Avatar
scott3392
Default STRANGE STARTING HABITS (part 2)
(75 coupe) It does it only at times but doing it more often now when I shut off the car & go to start it again the ignition has no power but when I jump the solenoid starter the power to the ignition comes back on I can tell when the fan blower kicks on I go turn the key & it will start up! I have changed the starter 3 times The starter on it now is a hi torque power master all help appreciated
(PART 2) thought I found the problem yesterday in one of the wires to starter replaced it no luck! BUT GET THIS I can tell it's going to happen because the raido picks up engine noise & you can bump the starter with ignition while running but wont ingage it.
Old Apr 16, 2008 | 07:18 AM
scott3392's Avatar
scott3392
Default More info
Last night when I shut it down it would not start with out help (engine was at running temp) went out this morning tried it (cold) & she started up on here own!!
Old Apr 16, 2008 | 10:55 PM
scott3392's Avatar
scott3392
Default Ok
Change out the coil & so on,change out negitive battery post & installed a ground from stsrter to frame 1300 will have the ingition switch swaped out will let you know what happens after that
Old Apr 17, 2008 | 12:17 AM
scott3392's Avatar
scott3392
Default Wow
Am I the first!! come on suggestions wanted talk to me
Old Apr 17, 2008 | 05:48 PM
DvBoard's Avatar
DvBoard
I wish i could be of help, but i have no idea so i'll give ya a bump. Does the battery die on you often?
Old Apr 17, 2008 | 06:25 PM
scott3392's Avatar
scott3392
Default Found It!!!!!!!!!!
After 2 tow bills in 3 days I found out what my problem was the fuse box inside the car & the wire harness on fire wall was loose tighten it up working fine now I was wondering why I was going threw so many starters (MAN I FEEL LIKE A NEW MAN)
To STRANGE STARTING HABITS (part 2)
