Lowering C3
Old Dec 13, 2001 | 05:45 PM
DaveMerth's Avatar
DaveMerth
Default Lowering C3
Hello everyone. I am new to the forum. I purchased an 80 vette in May and am in the restoration process. I am currently having a 355 built for it. I am also replacing all the worn out bushings, steering components, and everything else I see that needs replacing. I would really like to drop the car a good 2 to 3 inches, but am unsure about what companies make good lowering springs for the front and I am totally unsure on how to lower the rear of the car. What would be a good setup for lowering the car? Thankyou for the help!
Dave
Old Dec 13, 2001 | 05:52 PM
Stingy74's Avatar
Stingy74
Default Re: Lowering C3 (DaveMerth)
Hi, welcome to the forum. As you can see from my picture below, I lowered the front and back of my car. I used the F-41 550lb coils in the front without spacers to acheive almost no gap between the fender and top of the tire. For the back I got 10" end bolts with the nuts turned about 3/4 of the way down. The back could probably come down 1/2" or more or wherever the heck I want it. I should also mention that my tires are only 25.6" tall, a fair amount shorter than stock.
[Modified by Stingy74, 4:17 PM 12/13/2001]
Old Dec 13, 2001 | 06:07 PM
Stingy74's Avatar
Stingy74
I just realized that you said you weren't sure how to lower the back. I went out into the garage and took a few pictures to show you how.
This is my fiberglass spring (yours may be a 7 or 9 leaf steel spring) and the extended bolts that came with it which are about 7" long (not the 10" ones I mentioned earlier). As you turn the nut on the bolt so it get's closer to the bottom the car will get lower. If you are using stock length bolts you may run out of bolt and not be happy with the height of the car. This is where you have to get the longer bolts so you have more room to adjust. Keep in mind though that as you raise or lower any car you will be changing the alignment, sometimes to the point that you could wear tires out prematuraly.
[Modified by Stingy74, 4:20 PM 12/13/2001]
Old Dec 13, 2001 | 06:19 PM
ScubaJKD's Avatar
ScubaJKD
You can buy the longer bolt kit for lowering the rear end from any of the majors. I have had great luck with http://www.vettebrakes.com/
:seeya
Old Dec 13, 2001 | 07:56 PM
flynhi's Avatar
flynhi
Default Re: Lowering C3 (ScubaJKD)
Be careful with this. See the archive article from the Vette Improvement Program on suspensions. Do not adjust the rear beyond the point where the half shaft is level. It will really screw up the geometry and accelerate tire wear.
Old Dec 14, 2001 | 03:29 AM
DaveMerth's Avatar
DaveMerth
Default Re: Lowering C3 (Stingy74)
Id like to thank both of you guys for your help, and detailed photos.
Dave
Old Dec 14, 2001 | 04:16 AM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
On my 1980 I installed the 550 lb springs and it now sits higher than before. I would just cut one coil, but that increases the spring rate, and the 550's cause enough squeeks and rattles.
So, I will soon be installing some 460 lb springs, starting with one full coil cut and working from there until I get the right height.
Old Dec 14, 2001 | 07:33 AM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Because my shocks were shot, I had no rear swaybar, I wanted to replace the heavy steel leaf with a modern lightweight fiberglass spring, etc., etc..... I bought the VetteBrakes Street & Slalom suspension kit. This included new front coil springs also. This kit lowered my car in the front, and allows the rear to be adjusted in height. A big improvement over my 27 yr old worn out suspension.
My tires are 26" versus 27" so that too lowered the car.
[Modified by SmokedTires, 5:34 AM 12/14/2001]
Old Dec 14, 2001 | 09:34 AM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Default Re: Lowering C3 (SmokedTires)
The front end is hard to lower to the right height, I have the 550's and it's still too high!
Old Dec 14, 2001 | 11:40 AM
Stingy74's Avatar
Stingy74
Default Re: Lowering C3 (427V8)
I can't beleive some of you guys aren't happy with the height of your cars with the 550lb springs. They did exactly what I wanted them to, and as you can see there is almost no gap between the tire and front fenders on my 74. And to top things off my tires are only 25.6" tall. If they were 27" it might look like it's too low.
Old Dec 14, 2001 | 02:19 PM
71roadster's Avatar
71roadster
Default Re: Lowering C3 (BSeery)
B
Are you sure the springs are seated correctly? Be careful about cutting those 460 springs. I cut off 3/4 a coil and it was perfect. Any lower and I would be asking for trouble. The headers already occasionally scrape on large speed bumps or odd driveways.
Chris
Old Dec 14, 2001 | 04:00 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Be carefull if you lower the front with an '80. I cut one coil off and I am happy.
The car is 26.5 inches from wheel well to pavement and I would not like to go any lower because the spoiler on the front is now only 2 inches of the ground.
You kinda have to plan how you get in and out of parking lots, not so bad because it's not a daily driver. Older Vettes can get away with lower because they don't have the spoiler ( air dam ).
Old Dec 14, 2001 | 05:08 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Default Re: Lowering C3 (71roadster)
B
Chris
Ditto here. I cut 3/4 of a coil from the front springs and wouldn't go any lower witout switching to side exhaust. I'm at 26.5 inches in the front(fender lip). Double check seating of the the top of the coil in it's socket. If its not seated properly your front end wil look like its on stilts. :D
To Lowering C3
