Pushrod wear at guides
Old Apr 17, 2008 | 07:03 PM
Blues77's Avatar
Blues77
Default Pushrod wear at guides
Trick flow heads, with Erson Pushrods. Some of the guides needed the openings widened just so the pushrods could fit, others fit fairly easy. Do I just need to widen them out some more? I hear some pretty bad ticking, most likely the pushrod hitting the guide? Can I continue to use the pushrods that have damage?
Old Apr 17, 2008 | 07:18 PM
Scott Marzahl's Avatar
Scott Marzahl
Did you make sure to get hardened pushrods for use with guide plates??
Old Apr 17, 2008 | 07:20 PM
A88FXRS's Avatar
A88FXRS
wonder where all that metal is going ?
Old Apr 17, 2008 | 07:35 PM
Blues77's Avatar
Blues77
Scott - Yea ... the box says to use the guide plates, and that they are hardened pushrods (Erson). Then again the box and pushrods are probably 20 years old. They where bought from an extended friend who had old unused parts around. How much play should there be between push rod and guide plate?
A88 - I definitely will be changing some oil.
Old Apr 17, 2008 | 07:45 PM
540 RAT's Avatar
540 RAT
With Comp Cams guide plates and pushrods, my 540 had around .010-.012 clearance. So shoot for somewhere around that much and you should be in good shape. You just want some clearance without any binding.
Old Apr 17, 2008 | 08:34 PM
Cory1970's Avatar
Cory1970
There is your problem, guides should not "need" opening if they are installed correctly. If your valves and rockers studs have not been improperly installed from a bad rebuild, they should be on the same plane. If they are on the same plane, no clearance on the guide plate should be necessary.
If they were hitting, then the guide was not properly installed on the rocker stud. The guides usually can be slightly moved from side to side before the stud is completely tight, this is so they can be aligned. Most likely, they were not aligned on your heads properly.
No, you should not continue to use those push rods. They are now weak and will continue to degrade and put metal in your motor. They might even break in half.
You might be able to reuse those guide plates if they are deburred and polished otherwise they will eat the next set of push rods,.... The problem is, now that your have "opened" them up, the clearances will be forever off. The point of the guide is to keep the push rod aligned, via tight clearances. I would junk those guides ASAP. Guides are cheap, so save your motor and buy new ones.
Old Dec 12, 2009 | 02:54 AM
Blues77's Avatar
Blues77
Resurrecting my old thread!! I am thinking of going with self aligning rockers , and ditching the pushrod guides. The current ones are pretty trashed and trick flow doesn't make replacements for the first gen heads. Anyone run with self aligning rockers on trick flow heads. Any thoughts appreciated..
Old Dec 12, 2009 | 11:14 PM
drwet's Avatar
drwet
Your picture takes me back. I had exactly the same thing happen to one of my engines many years ago. The problem is the pushrods are not hardened for use with guideplates. Be happy you caught it before a pushrod broke. You will need to replace your guideplates because you modified them,and get a set of hardened pushrods.
Old Dec 13, 2009 | 09:57 AM
Blues77's Avatar
Blues77
Thanks for the reply. Trickflow doesn't make replacements for the first gen heads I have. So I was thinking of getting some non-hardened pushrods and self-aligning rockers. Wondering if that's feasible with these heads.
Old Dec 13, 2009 | 10:50 AM
midyearvette's Avatar
midyearvette
self aligining rockers are for later model heads with taller valve stems than normal..careful here...you may want to stick with the right set up for your heads....you dont want the rockers with the self aligning roller tips to push on yout retainers or keepers......good luck....
Old Dec 13, 2009 | 09:51 PM
drwet's Avatar
drwet
I wonder if it would be possible to weld the guideplates up and have them re-machined to the original size. What about getting pushrods in a larger diameter and having the guideplates machined to the new pushrod size? I have a set of the old original Trick Flow heads on my 79and I'm disappointed but not surprised to find they are no longer servicing those heads. Not the best company to deal with.
Old Dec 13, 2009 | 10:20 PM
OMF's Avatar
OMF
I run guided comp roller rocker on my vortec heads. While I was buying the rockers, I compared them to a set of unguided ones, and the only difference I could see was the small casting that surrounds the valve to "guide" the rocker......That little bit costs $150 bucks more here in Canada.
I'd suggest comparing a set yourself at the local speed parts house and see if you can spot any difference.
To Pushrod wear at guides
