diff. swap 70s into 81
http://www.vansteel.com/photos/index...thumbs&e=4&s=1
I'm half kinda in the process of doing this myself. What I've found is this:
The 1/2 shaft Ujoints of the auto are smaller than every other C3. The Manuals have the same size as the 70's. If you've got an auto, you'll need new halfshafts & flanges (Yoke & Spindle flanges - the 81 has a 1 piece unit here) to fit the bigger Ujoints - unless you can find a joint that's got a small side & a big side to mate up - Duntov may sell this but they advertise it for driveshafts.
The Driveshaft Ujoint is different also - It's the same size as an 81 auto halfshaft. You may need to lengthen your driveshaft. Should be able to have the Driveshaft place put the right yoke on it to match the pinion yoke.
You'll need the Strut rod bracket for the Iron Diff, it mounts to the case, where the 81 sandwiches the case & cover. The Strut rods are different as well, due to the differing position of the bracket - the 81 ends are angled.
The 81 rear cover "batwing" has 6 bolts that actually go into the case, the other 4 holes are for the strut rod bracket & sandwich the case. The Iron Diff has 8 holes around the perimeter.
I've read of people having the front differential mount be too close to the pinion, causing the diff to point down in the front. Others do not have this problem. You should be able to fab up a new bracket pretty easily if needed.
Other than that, it looks plug & Play.
Like I said, I'm gathering parts... I've got an auto 81. Found a rear end from a 68-70 that has everything I need except the gear ratio I want... Anybody want to buy a good condition diff with 4.56s in it??
THe Spicer P/Ns for the U-joints that I know are as follows:
81 auto halfshaft & Iron Diff Driveshaft (may vary depending on tranny) - P/N 5-790x
81 manual & all 68-79 halfshafts - P/N 5-799x
Hope this helps.
Dan
