73 motor surging
Old Apr 17, 2008 | 10:42 PM
wmkj69's Avatar
wmkj69
Default 73 motor surging
hey everyone, here is what I have been told. First, I have checked fuel pump, plugs, wires, dist., points, vacuum lines, checked for leaks in fuel lines, etc. The car has a carter AFB carb on it. Was told by the previous owner that he had a problem with the motor surging a little over a year ago. They rebuilt the "carter carb" and it ran fine. I have been told by a co-worker that Carter carbs are JUNK and that is my problem. Now, I don't mind spending the money for a Rochester, or a Holley, If that is the problem. HEY FOLKS, WHAT DO YOU THINK?
Old Apr 17, 2008 | 10:51 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I would make sure the timing is set correctly first. Use Lars paper as a guide to be sure timing is set correctly.
Lars Timing Paper
Old Apr 18, 2008 | 07:05 AM
SH-60B's Avatar
SH-60B
Check further into the distributor than just the timing. Make sure the mechanical advance has both springs and they are the proper ones.
Old Apr 18, 2008 | 08:04 AM
BarryK's Avatar
BarryK
surging can be an indication of too much vacuum advance on the timing. i'd check the timing setup.
Old Apr 18, 2008 | 09:09 AM
Matt Gruber's Avatar
Matt Gruber
points ask for regular tuning. got rid of mine in '92.
a new electronic dist is nice on any old car imo.
To 73 motor surging
