200r4 lockup wiring
Old Apr 18, 2008 | 01:03 AM
V-Rod's Avatar
V-Rod
Default 200r4 lockup wiring
On the lockup wiring when you press on the brakes the power going into the transmission shouldshut down correct?
Old Apr 18, 2008 | 07:39 AM
rosslato's Avatar
rosslato
yes it'll come out of lockup. if u just step on the brake for a lil bit it'll go back to lockup unles it shifted into 3gear. it's a beautiful thing
Old Apr 18, 2008 | 08:33 AM
redwingvette's Avatar
redwingvette
Yes, the brake pedel should cut power to the convertor but as soon as you let off it will ock back up.
I don't like that because some times I haven't slowed down enough for the trans to downshift on its own yet enough that the motor starts to lugg, like 30-35 mph. so I end up having to manually downshift.
I would like to give one of these a try, it will automatically unlock the convertor under 40mph:
B&M controller
Old Apr 18, 2008 | 10:41 AM
V-Rod's Avatar
V-Rod
Glad to know I got it right didn't want to do any more hesd stands under the dash, Redwing I think I read where you mentioned the B&M before I looked at it sounds like good system but my CC transducer is broken inside so my speedo doesn't work I am trying to find a unit local before I send off.
Old Apr 18, 2008 | 12:40 PM
Tankers's Avatar
Tankers
B&M controller
If anyone is using one of these, sure would like to know how well it works. Thinking about getting one.
To 200r4 lockup wiring
