Depends on the condistion of the bumpers (urathan(orginal) or fiberglass(replaced why?)) frame, bird cage, undercarriage, breaks, motor, trans and clutch. While it looks all together and like it has been repainted, does it run and what else does not work. I have seen good runners with good frame, new brakes, suspention, trans and motor go for $10,000.
But I would not guess a quote without looking in detail underneath the surface and car. Those are the parts (noted above) can run a $1,000 or more each to fix, and would reduce the value of the car, even if you intend to rebuild it.
