68/69 door panel question
Old Apr 19, 2008 | 02:36 PM
Woodie's Avatar
Woodie
Default 68/69 door panel question
Will a 69 door panel fit right on a 68 door with no problems?
Old Apr 19, 2008 | 03:29 PM
wombvette's Avatar
wombvette
You can make it fit. I dont know about the no problems part. There are technical differences that will require some work.
Old Apr 19, 2008 | 05:21 PM
Ironcross's Avatar
Ironcross
Yes it fits, but its not the correct door panel. Unless you dont care about correctness it has the wrong pattern and inside door pull. Each year carries a different cosmetic appearance, the rest is the same.
Old Apr 19, 2008 | 07:08 PM
RHD '68 L89's Avatar
RHD '68 L89
If you only fit one you will notice the difference between left and right.
The 69 panel is thinner than the 68 and well as being cosmetically different.
If you fit a pair then it would not be really obvious.
Old Apr 19, 2008 | 07:13 PM
1Fordman's Avatar
1Fordman
The 68 door panel has the cats whiskers or fuzzy attached to a metal bracket that mounts to the inner door skin. I believe on the 69 door panel the fuzzy mounts to the door panel.
Old Apr 19, 2008 | 08:53 PM
Ironcross's Avatar
Ironcross
This is correct!
To 68/69 door panel question
