keep breaking the starter's nose
Old Apr 20, 2008 | 02:47 PM
rickkym's Avatar
rickkym
Default keep breaking the starter's nose
my son bought a 66 chevelle which he was told has a corvette motor in it, supposedly a 383 but it's definately a small block chev. When he bought it the starter looked brand new, but we took it out and the 'nose' (bendix cover?) was cracked all the way around. We figured it got dropped or something so we buy a new one. Three startups later its making noise again and guess what, the brand new starter is broken the same way.
It looks like the bendix shoots out and breaks the nose off. How do we fix this? Is there some special starter we need to get? It's an atuomatic transmission I have no idea which one.
Thanks so much!!
Old Apr 20, 2008 | 03:45 PM
jimweis's Avatar
jimweis
Thanks so much!!
Sounds like you need to shim the starter. Does it sound odd when cranking?
Old Apr 20, 2008 | 04:16 PM
longbros's Avatar
longbros
I have never seen a starter break because the bendix slams the housing, but I have seen starters break because the initial timing is set too high.
Old Apr 20, 2008 | 04:23 PM
Ironcross's Avatar
Ironcross
Timing causing the engine to kick back can brake the nose off. They dont like to suddenly run backwards.
Old Apr 20, 2008 | 04:42 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Originally Posted by Ironcross
Timing causing the engine to kick back can brake the nose off. They dont like suddenly run backwards.
Old Apr 20, 2008 | 05:58 PM
stingr69's Avatar
stingr69
Make sure that you have the brace bolted to the front of the starter that attaches to the side of the engine block. That will help.
-Mark.
Old Apr 20, 2008 | 08:50 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I've had this happen on an SBC that doesn't want to run right. I've considered dropping my L48 in it's place when my new engine is built.
Old Apr 21, 2008 | 08:32 AM
rickkym's Avatar
rickkym
I guess a backfire makes more sense then the bendix breaking it off.
And I'll have to look if there is a brace on the starter, I'm thinking there was just one bolt that went up into the engine.
Thanks, you guys rock!!
Old Apr 21, 2008 | 09:01 AM
moosie982's Avatar
moosie982
If you only have 1 bolt holding your starter onto the engine then that is your problem right there, it takes 2 and the ones from factory original with the serrrated shanks are the only ones to use,,,, I've found out the hard way. The brace on the other end of the starter is also important to have, any less and its a crap shoot.
Good luck, Peace,,, Moosie
Old Apr 21, 2008 | 09:08 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Definitely needs 2 bolts.
To keep breaking the starter's nose
