I'd go with the sandblasting - your never going to see the inside of the frame anyways...
Frames generally rot from the inside out. It is better to get all the rust off and out, then get something on and in there to keep it from coming back.
Actually I don't think you will be able to treat all the surfaces on the interior of the frame as they should unless the intire frame is dipped in a protective paint of some sort. That way you would get even more rust.
Rust itsself doesn't do anything, it's moisture that kills.
I would advice against dipping it.
I had my frame blasted, then treated with zinc and then powdercoated. The zinc will protect the inside of the frame also because of its properties.
Exactly. If you think rust is what kills a frame, you are incorrect. It is moisture which is the issue here...not the rust itself. THere is a process where you spray waxy oil into the frame rails which prevents rust from forming, and it is relatively cheap too.
I had mine dipped because I was concerned about the inside of the frame. I used "Restoration Depot" in Wauchula, Florida and I DO NOT recommend them for this. It took them 4 weeks longer than they said and then they didn't even get the frame completely clean. I had to then pay somebody to finish it up with a sandblaster. The company was a pain to deal with all the way around.
Afterwards, I had the frame powder coated by Van Steel and then I did the spray wax thing inside the frame to protect it. It's hard to say how well the wax covered the inside but I'm happy with it overall I think.
[B]Acid Pros:Acid Cons:
Surface is extremely smooth, which regular paint won't stick too. Powdercoating, on the other hand, will stick just fine to it.
This may be a stupid question, but can you not etch the frame after dipping?
I haven't done it yet, not sure if I am going to either...my car is nevr going to see the rain and it is really dry here in calgary. Here's an old thread...
I just hap mine sandblasted and powder coated for $450. Dipping was an attractive option but it would have cost about $650 more. I was going to use Redi-Strip. http://www.redistripco.com/
They don't use acid. They have an alkaline imersion process. You don't want acid as it cannot be completely washed out and will continue to corrode and also seep onto the outside and remove your finish!
Like others here have said it is the moisture that corrodes the cars. For instance why do cars from the West look so much better? Low moisture. In other words do the outside and keep it in the garage and it will last as long as you need it to.
If you want, you can use a coating on the inside, I believe Eastwood sells something. Or you can use boiled linseed oil. It crawls up the walls on the inside and coats the metal and becomes sticky. They have used this on the inside of steel tube airframes for 50+ years. It works. You would need a couple gallons or more to coat the frame and it should be done after finishing the outside.
