Hooker sidepipes
Old Apr 21, 2008 | 03:48 PM
corvette744's Avatar
corvette744
Default Hooker sidepipes
Has anyone ever tried installing the hooker sidepipes,on a big block 71-78 vett body with aftermarket dart heads.I no the heads are a half inch higher than stock-but their has to be a way.I want them on my 540.
Old Apr 21, 2008 | 04:53 PM
69ttop502's Avatar
69ttop502
I had to modify the Hookers to work on my 502 powered 69 with AFR heads. The exhaust port is only raised .375 which is the same as the Dart heads I believe. I had to cut and reweld 5 tubes, very expensive if you can't do it yourself.
If you are not in a hurry, I am going to sell my headers which are black ceramic coated and in great shape. Probably won't get them off for 6 weeks or so. I am going to get a set of Stahl's who do make a header for raised port heads. Very expensive and a little different design.
Bill
Old Apr 21, 2008 | 04:59 PM
corvette744
Default hooker
Thanks was that on the passenger side i assume.Dont happen to have any pic of the welding do ya.
Old Apr 21, 2008 | 05:05 PM
69ttop502's Avatar
69ttop502
Sorry, I don't and am 1000 miles from the car, but I basically cut the tubes about 1 inch from the flange and rewelded. It was all 4 on the drivers side and 1 on the passenger side. Watch the plug access as well. Definitely will have to do some major dimpling as well.
Old Apr 21, 2008 | 09:41 PM
ZL1powr's Avatar
ZL1powr
I have Dart Pro 1's on mine. It was an easy mod to the headers to make them fit. I cut about three fourths to seven eithts through all four pipes on each side from the bottom at the flange. I then bent the pipes down about 3/8" to close up the cuts then re-welded the cuts at the flange. Since the welds are mostly on the underside and at the flange they are not hardly visible. Both sides fit great with this mod.
Old Apr 21, 2008 | 10:01 PM
wrc69v's Avatar
wrc69v
I have a 540 with Dart Pro Ones and both side pipes went on no problem. The passenger side was a little high, so i jumped on it and gave myself more clearence. Unless the fender is lower on your car, I have 69.
Good Luck
Old Apr 21, 2008 | 10:35 PM
pef427's Avatar
pef427
I like that idea.
I have a Dart talldeck 598 with the Dart Pro 1's and I found it necessary to cut the entire flange off, bolt a new flange to the head, then bend each tube over and relase it letting it capture itself in the top of the flange. Then tack it in place. With the tubes free of the flange they were easy to bend. Then weld them up on the inside with a little die grinding to smooth out the welds. I sent them off to Jet Hot afterwards.
-P
Old Apr 22, 2008 | 12:57 AM
corvette744
Default God im glad to hear that
Tell me you guys have pics and the beers are on me.................
Old Apr 22, 2008 | 07:21 AM
bashcraft's Avatar
bashcraft
I've been trying to think of a way to do this without cutting my chrome hookers. How about angle milling the exhaust flange surface on the head to effectively do the same as you did?
Old Apr 22, 2008 | 01:27 PM
yellow94coupe's Avatar
yellow94coupe
The fastburn heads on the zz383 had taller ports than stock so I ran into a lot of clearance problems with the steering box. I thought it would require cutting and welding to reroute the tubes which would be a hassle since they are chrome. I figured I had nothing to lose by trying a hammer to put in a dent since it would get cut out anyway if it didn't work. A good sized dent did the trick and it doesn't seem to have an adverse effect on performance.
Old Apr 22, 2008 | 03:31 PM
Belgian1979vette's Avatar
Belgian1979vette
Do all Dart pro 1's have raised exhaust ports ? I have the ones for the SB ?
Old Apr 22, 2008 | 11:51 PM
corvette744
not sure belgian-just no the bb have .500 check darts site youll find it their.
Old Apr 23, 2008 | 06:42 AM
Fonz69's Avatar
Fonz69
Good Luck
Did the same and dimpled the LH @ the frame and had to clearance the #3 plug which is still very tight along with more denting @ the steering box.
as far as futher adjustment I was told put some rags on it and jump on them to get them to bend down enough to clear fenders
Did not want to weld as mine are jet hot coated
Old Apr 23, 2008 | 07:15 AM
corvette744
fonz69 you also had raised exhaust heads.Or were they stock.Everythime some tells me that they made them fit im ready to get them,i cant stand when a company says it will never work,that just makes want to do it all the more.
Old Apr 23, 2008 | 07:18 PM
Fonz69's Avatar
Fonz69
Yes I am running dart pro1 325cc aluminum heads
Mind you they are tight but if I knew there would be cutting and welding new parts I would have passed
But they did fit and the guy I bought my hard top from owns the car they used to mock up the header system and they look like they fit even better on a stock BB chevy
Old Apr 23, 2008 | 10:03 PM
Road-Race Vette's Avatar
0Road-Race Vette
Former Vendor
I had the same problem and just ordered a new set of headers and side pipes from STAHL. They make them to your heads, and the design of the header is worth about 30HP over the hookers.(according to them) I got mine and they fit just fine.
http://www.2ndgenrestorations.com
Old Apr 23, 2008 | 10:34 PM
corvette744
Hey road- race those dont look like the ones you have on in the website-or are they.THey look like hooker with the 4 pipes coming out under the rocker vents.If they arent the ones can you show a pic of the stahls installed on car.I want to see how they look from outside engine bay looking at side of car.Thank's
To Hooker sidepipes
Old Apr 24, 2008 | 09:52 AM
0Road-Race Vette
Former Vendor
those are the STAHLS. They dont look like hookers at all. The four pipes dont come out the side.
Old Apr 24, 2008 | 11:47 PM
pef427's Avatar
pef427
I really like my Hookers or I wouldn't have went to all the trouble to re-fab them to work. But, those just look Ballsy!
-P
Old Apr 25, 2008 | 12:22 AM
corvette744
i tought you were talking about the white #2 car,sorry those do look awesome.Hey do they have longer mufflers also.
