Any other differences besides the actuator rod? The doors, linkages, hinges, etc?
I think I read that there are more support brackets on the 69up. I'll have to take a look at my 68 and my brothers 69 in the moring to verify this and see if I can see any other differences.
Budman is correct about the squirters but you can use either squirter setup on whatever year wiper door assembly (68-72)
The 69 door assembly has an vacuum switch for the windsheild wiper door system that the 68's don't have. The 69 squirters were on the windshield arms, the 68 squirters were attached to the underside of the wiper assembly door.
The 68 and early 69, had "coffee can" vacuum actuators, and the later 69 and up cars had an actuator that looks like two little pie pans joined together. These two different style actuators attach to the firewall with different brackets. Also as said above, the actuators have different threads/rod sizes on the actuator rod that pushes/pulls the door open/shut.
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
sounds like you guys covered it
The only thing I would add as a minor point is the 68 uses a micro switch tied into the wiring harness with a metal arm connecetd to the wiper door to engage it, to tell the wiper motor when the door is fully opened
I have both the 68 and 69 linkages. The only difference these old eyes could see was the 69 has 2 additional brackets (one on each side) that bolts to the cowl for additional support and the 68 has a 1/4" rod for the actuator and the 69 has a 5/16's rod. I'm using the 69 linkage on my 68.
