Help with a Hurst Shifter for 80
Old Apr 22, 2008 | 01:41 PM
joefloyd's Avatar
joefloyd
Default Help with a Hurst Shifter for 80
I just had my Hurst Shifter installed by a local garage; if I had access to a lift I would have done it myself. The shop did a good job installing it, but it seams that the 3 rd gear stop needs adjusting. My question is can I access the adjusting bolt from the inside if I remove the console and the lower boot or does it have to be done from under the car? I don't trust the shop to remove the console without breaking it. I removed it myself before the install. If it can be done from the top inside the car I will do it myself. If it can't I that I won't take the console out. Hope someone can give me the answer !!!
Thanks Joe.
