Pull the steering column out of the car. Take note of the aluminum capsules that mount the steering column up into the instrument cluster. The capsules are designed to allow the steering column to "breakaway" and slide forward. The capsules should be tight in the column bracket.
Also when you pull the steering column I can provide dimensions that can tell you if it has collapsed or not.
Jim
Jim
The column is already out. My problem is the previous owner thought he was a mechanic, I don't know if he's removed and re fitted the steering coloumn he did do some interior meddling. The column is difficult to fit. It has to be bolted to the firewall before the slots are forward enough to fit the bolts.
Those dimensions would be a great help.
Reason: typo
Just a note the whole front of the frame was bent down(it was on axel stands), which would have pulled the column out (in my humble opinion). We are using it as a double check when it is straightened to see if the frame is back up where it should be.
Do you have a standard (non-adjustable) or a T&T column?
T&T Column
The length of a T&T steering shaft from the lower bearing to the end of the shaft should be 4.70 inches.
The overall steering shaft length (telescope shaft retracted) 38.60 inches.
The overall steering shaft length (telescope shaft extended) 40.70 inches.
Runout of the lower steering shaft relative to the steering column jacket should not exceed 0.040 TIR.
Standard Column
The length of a standard column steering shaft from the lower bearing to the end of the shaft should be 4.55 inches.
The overall steering shaft length should be 39.69 inches.
Runout of the upper steering shaft relative to the lock housing should not exceed 0.070 TIR.
I don't know why the T&T column has a runout spec with respect to the lower shaft, whereas the standard column has a runout spec relative to the upper end of the shaft.
