Pinion bearing bad???
Old Apr 23, 2008 | 04:08 PM
Laird1978's Avatar
Laird1978
Default Pinion bearing bad???
My 78 has a grinding noise coming from the rear end. At first I thought of wheel bearings. My mechanic said the noise should change with mph. It does not. I can get it to go away with a slight change in throttle. But if I push on it again the noise comes back. Could this be a bad pinion bearing? How would I check further for that? Any other ideas? I am not in a rush since I am unemployed and need tires also. Thanks, Laird
Old Apr 23, 2008 | 10:32 PM
maddmickey's Avatar
maddmickey
It sounds to me like a pinion or a side bearing. On solid axle cars its easy to pull the front pinion bearing and check it first, but on a vette that might not be so easy. You should probably pull the diff out and check them all, just to be safe. I just did one on an s-10 that I was sure was just the pinion bearing. When I pulled the diff it had a bad side bearing too!! Good luck
Old Apr 24, 2008 | 12:14 AM
wombvette's Avatar
wombvette
About every 78 made ate the half shaft yokes eventually. I would look at those too.
To Pinion bearing bad???
By Michael S. Palmer | 2026-06-03 09:39:05
