Torque specitications help on my 77 s/b
Old Apr 26, 2008 | 02:01 AM
myc3c6's Avatar
myc3c6
Cruising
Default Torque specitications help on my 77 s/b
I replaced my old front control arm bushings on my 77 S/B with Urethane bushings, and can not find in any of the books I have the Torque specitications for the bolts that are bolted in to the front and back end for the bushings for the upper & lower control arm, of the arm-pivot ( not the bolts to the frame). can anyone help me with this. Thanks Rob.
Old Apr 26, 2008 | 10:50 AM
76projectstingray's Avatar
76projectstingray
my book calls for 60 ft lbs. Make sure the threads are clean and use loctite so they do not back out.
Old Apr 26, 2008 | 11:02 AM
Glassbowtie77's Avatar
Glassbowtie77
Here you go. http://www.vbandp.com/instructions/h...specsR0102.htm
Old Apr 26, 2008 | 11:04 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Be sure to torque the bushings at ride height only.
Old Apr 26, 2008 | 12:05 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
That's good advice...for rubber bushings only. Poly bushings rotate, so you can torque them properly at any time.
Old Apr 27, 2008 | 09:42 PM
myc3c6's Avatar
myc3c6
Cruising
Default Thanks for the Info.
Thanks for all the help this will get me finished with the front end. Now the next is the Rear suspension & body mounts
To Torque specitications help on my 77 s/b
